Cooling fan does not come on
This is controlled by a cooling fan sensor/temperature sensor, as well as fuses, and a relay. These will have to be checked.
Make sure your coolant level is full, the coolant temperature switch won't work if the level is too low. If coolant is low, you need to find out where it went to by pressure testing the cooling system.
If it's not low and the fuses are good, the relay is working:
The fan should be tested, bypassing any sensors to make sure it is functioning properly.
The sensors can be tested to be sure they are working properly at the correct temperature with a voltmeter/ohm meter.
Reverse troubleshooting the wiring and ignition is the next step if you haven't found the problem.
Good luck !
