Maytag Stove / Oven / Range Cooktop - 12001853 Logo
A
Anonymous Posted on Mar 18, 2013
How to replace spark module on mgs5870adc - Maytag Stove / Oven / Range Cooktop - 12001853
Have a thermador psc364gdzs the spark does not work for the gridle
The spark module is in the ignition circuit for the gas burners. When a burner control knob is turned to the Lite position, it provides voltage to the spark electrodes on the gas burners. If the spark module fails to provide the electrodes with voltage, then it should be replaced.
tip
Cooktop Range Stove spark ignition does not work
You go to light the burner on your cooktop and the spark does not work.
What can the problem be? In most cases the problem will be because the
spark ignition module has gone bad. This spark module is a piece of electronics that produces a harmless electric spark at 2-4 pulses per second. Because the spark is a ultra low amperage spark, it is not dangerous.
A typical spark ignition will look similar to this.
This box is usually in a metal box located somewhere under the cooktop of your stove or in the back panel of your stove. The easiest way to find this is to simply follow the electric wires that go from the spark ignition box to the spark tip located at each of the burners.
The spark is activated by a switch that is located behind each of the burner control knobs. When one of the switches is turned on, all of the burners spark at the same time. The spark switch will look something like this.
To troubleshoot the spark ignition you need to determine if the system is wired in series or parallel. If the system is a series system and one is not sparking, then none will spark.
Almost every time if the spark is not working, it is because of a bad switch. To isolate which switch it is, turn each switch till you find the one that does not activate the module to spark. You can confirm this by pulling the two wires off of the switch and touching them together. If you get spark you know that the switch is bad. If no spark happens then either then a wire is bad or the module is bad. If none of the switches cause the module to spark then it is a good assumption that the spark module is bad.
By checking through these procedures you will be able to tell whether your problems are caused by a bad switch, a bad wire, or a bad spark ignition module. You will discover almost every time that the switch behind the burner is the part that needs to be replaced.
on Aug 18, 2010 • Cooktops
1helpful
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
My Dacor PGM365-01 main burner continues to spark after I place a pot or pan over it. I just replaced the spark module - still happening. Valve? Micro-switch? Clean the burner?
What is your altitude?I have the same problem and was told by Dacor that I should have the high altitude version. I'm at 5000'
How do I replace spark ignitor on GE JGP963SEF1SS gas cooktop?
If none of your burners are igniting, you need a new Spark Module. If only 1 or 2 of your burners are not igniting, you may need a Spark Igniter. Click on the pictures below for a larger image.
The Spark Module is number 318 in the following diagram (underneath the burners):
The Spark Igniter is number 154 in the following diagram:
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 02, 2011 • GE Cooktops
Piezo igniter won't quit
Possible stuck burner switch or failed spark module. Unplug unit. Remove wires from burner switches at module and plug back in. If it starts sparking, replace module. If it stops, then replace switch harness.
1helpful
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Have Jenn-Air 36" gas cooktop w. 5 burners, black. Mdl JGC8536ADB. Plastic knobs keep splitting, even if we remember to push down before turning. Have replaced two sets and now we're down to two working...
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
3answers
Electronic igniter stopped working
I recorded video to let u see how its done. Problem Was : non of the burners would ignite (no sparks when knob is turned on). First sigh of bad spark module, but I got spark switches(they harness) as well just in case - One of the spark switches was bad - Check my video how I replaced them. Non of the screws was coming out.
Top Maytag Cooktops Experts
Paul Carew
Stan Ford
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
