The icon at top of screen for volume has disappeared and when i go to system preferences it will not let me un check it ..please help thanks
SOURCE: Dark Screen
Try connecting to an external monitor. If the monitor displays correctly, then the problem is with either the inverter or the screen.
SOURCE: No sound on Powerbook G4
hey,
so not to be obvious but you have one of two problems either hardware or software. there is a way to check but you need to do a few things. first you should try creating a new user account and see if the volume problem still exists. you create a new user through system prefs/accounts. if that doesn’t work you should try a pram reset by holding down the cmd, option, r, p, key at boot. IF you have never done this before you want to hear the startup chimes at least 3 times then let the computer restart. if that still doesn’t work you should try an archive and install of the os from the discs if you still have them, and if none of that work you most likely have a hardware issue and either the logic board needs to be replaced or the speakers are bad. but either way its going to cost money if there is a hardware issue and you might consider a new computer, im just being honest.
Testimonial: "Thanks. I actually got it working by going to Audio MIDI setup, Aud.Output Ch. M was clicked to mute. I unclicked it. I have no idea what it means."
SOURCE: I can't get any sound form my powerbook g4. the
Try to download the latest version of iTunes for Mac, click on this link http://www.apple.com/itunes/download/ and install, see it it works.
SOURCE: MacBook Air sound/disappeared
This is a widespread hardware issue with the MacBook Air. You are not alone. See:
http://discussions.apple.com/thread.jspa?threadID=1736638&tstart=15
Some users report that replacing the Audio Board Flex Cable corrects the problem, but others report that the correction is only temporary.
If your machine is still under warranty, I would get it back to an Apple repair facility immediately. If it is not, you will still need to get it to a repair facility, but bring along the above URL and suggest that Apple treat it as a warranty extension issue.
SOURCE: Have a powerbook G4 15 Display Issue
First, make a magic pass of your hands, like David Copperfield. Then press these four keys: control-option-command-8. Presto!
If no presto (oddly, there's no presto on my system, and I know it's not for lack of mana), visit System Preferences / Universal Access and click the button that says "black on white."
