Hi there, The speaker volume for the microphone and line-in
may be muted or turned down. Use the following steps to check the
speaker volume levels for line-in and microphone.
in Volume Properties By
Right Click on Volume Icon in your Task Bar and then click on properties
and then Advanced and then uncheck mute button under Microphone.
or
Hope this helps.
::Look EASIEST WAY OF THEM ALL RIGHT HERE::
[1] --> Right Click the Volume Icon at the bottom right corner of your screen [The Task bar].
[2] --> Click [Playback Devices]
[3] --> Right Click the [Speakers] Icon and click Properties
[4] --> Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback (By clicking the unmute icon, than slide the volume up to where you prefer it... Simple I hope I was able to help someone with this...
SOURCE: How do I unmute my
Click on Start - Control Panel - Sound and Audio Devices - Volume Control.
If the Mic option isn't listed Click on Options - Properties and check the box next to Mic.
it should then be listed in your volume contol window, adjust accordngly.
SOURCE: Desktop, accer computer, can't unmute
Hi queen17186...
Go to the bottom right hand side of your computer screen, look for the speaker icon, double click the speaker icon, a window will open and show you the volume control, make sure none of those are checked "mute".
Then go to the top of that window left hand side and click on "options"then click "properties" scroll down and make sure "microphone" is not checked.
This should clear your microphone problem.
Please take time to rate me
