Plumbing Logo
Anonymous Posted on Feb 19, 2013
Stuck pfister faucet sleeve
'87 lavatory pfister wide faucet drips and the replacement stem inserts into a 3 part sleeve that has a rubber washer in the bottom section. I removed the inner plunger stem easily, but just putting the new stem in , does not stop the drip . There are 3 recessed openings in this third sleeve for delivering the water to the spout, so I gerry-rigged a hook to attempt to loosen and remove the sleeve; but they wouldn't budge;they are stuck in the tap housing. How to remove this inner sleeve, so the washer can be replaced?
  • Anonymous Feb 20, 2013
    sprayed it with PB Blaster to try to get it loose. No luck yet! stinks!
  • Ed Wastrodowski
    Ed Wastrodowski Feb 25, 2013
    PB Blaster is described as" a Penetrating Catalyst Lubricant 16PB-THD, water repellant loosen rusted nuts, bolts or pipe threads ..
Ed Wastrodowski
Level 1:
Habit-Forming:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 25, 2013
Ed Wastrodowski
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
Questions
0
Helped
16870
Points
12
  2. Thanks to Danny Paccho I purchased a wrench to use in removing the sleeve from Geers Plumbing
  3. Then , removed the \'87 Price Pfister faucet housing from the basin by disconnecting the 2 pipes under the basin and removing the top basin nut; inserted the wrench into the top, turning counter-clockwise until it locked (er tightened a bit) and hammered it out ,gently?, to not damage the escutcheon threads , or the basin nut.
5 Related Answers
Thomas F. Schneider
  • 2715 Answers
  • Posted on Feb 08, 2009
SOURCE: How to remove the corroded valve seat housing in my tub faucet
Some seats ae rremovable and some or not Some take a hex(allen) wrench and some take a square (seat removal tool)  Most of us use a seat grinder. (another tool to dress up the seat (Remove material) past the seat damage. You will find any of these tools at any hardware store that sells plumbing parts. If the seats have a square or hex hole remove and replace rather that grind(dress)the seat. All right hand threads meaning turn counter clock wise to remove. Take old seat to the American Standard plmbing supply outlet and then will match it up. Good fix-in to ya.
Anonymous
  • 68 Answers
  • Posted on Apr 12, 2009
SOURCE: stuck spout
theres a little slide clip sometimes that sits inbetween the stem and faucet body look for that it may have one stopping your progress good luck
Bill Johnson
  • 306 Answers
  • Posted on Jul 29, 2009
SOURCE: Speakman shower faucet washer replacement
there may be two nuts,one for the stem and one for the stem barrel.if not then the stem does just screw out,may just have a build up of something on it,try and working it back and forth to try and break it loose,careful not to damage anything.
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jan 22, 2010
SOURCE: how do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
bryan farmer
  • 112 Answers
  • Posted on Jun 12, 2011
SOURCE: Moen Eva two handle lavatory faucet - hot water
Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
How to remove stem from valve assembly
These have a lifetime warranty. Call Price Pfister for free parts.
Use your hand or a strap wrench to unscrew the handle assembly. The tower under the handle just screws to the stem down at the counter level.
Here is a link to the parts list.
http://pfisterparts.faucetdirect.com/mediaBase/specifications/pfister_gt49_yp1_part.pdf#page=1
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
I replaced the cartridge, and O ring on my sink faucet, but there is still a drip,drip. On older faucets the metal valve seat could be replaced with a new seat after removing it with an Allen wrench. Don't...
On the hot and cold valve stems there should also be packing washers that should be checked. They are either made of rubber. they should be checked as well.
How do I remove handle of lavatory faucet to replace cartridge? The faucet is dripping and making a noise
There should be a small hole under each lever handle. Inside the hole is a handle setscrew. Use a 2.5mm hex wrench to loosen, not remove, the setscrew. turn the screw counter clockwise to loosen, and then the handel should just pull straight up and off the faucet. Here is a parts breakdown for the PRICE PFISTER Treviso Wide Lavatory Faucet T49-DK00.
The cold water handle is frozen in place. When I swap out the hot handle with it, it turns fine. How can I, or can I, unfreeze this frozen faucet handle? Model is 048nk00
Can you soak it in a type of penetrating oil to maybe free it up. Once freed up they make a grease for stem's maybe apply some to stem for smooth operation.
Handles are turning backwards.
take off circlip, flip over the ring that fits over the splined shaft. It has flat so it will only go on one way, replace circlip, now reversed.
Where does the rubber cup with the hole in it and the spring fit?
They go in the bottom of the stem on most two handle faucet's, Remove stem and replace spring and seat onto it.
Tub shower diverter stem on tub spout broke and need to have instructions for how to replace the ROD Diverter seal o ring in the spout.
you must replace the whole stem.you can get it at homedepot. first take the cover off over the stem. this should screw off or is held on with a allen key.then unscrew stem from valve body.make sure water is off to tub,just in case.
Top Price Pfister Plumbing Experts
john h
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
