20 Most Recent Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Questions & Answers
Replacement parts can be found on amazon. Click here Watkins Hand Soap Made Naturally Since 1868 and take a look. I hope this was helpful. Cheers
Price Pfister... • Answered on Feb 08, 2019
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Price Pfister... • Answered on Feb 25, 2018
If you just installed it check to see if it has a water saving feature that in some homes and almost restrict all the water force
Price Pfister... • Answered on Feb 18, 2018
if your faucet is new....the spout was put together wrong and it needs to be removed and re-attached correctly...(friction washer/ring in wrong position).....if not new....spray some penetrating oil on the connection that is supposed to swivel....make sure the surface is dry and try to avoid overspray. let it sit for 15 min...then spray it again...and again let it sit ....after sitting for a few minutes.....gently try to move the spout side to side...if no change...repeat the first processs...and continue to repeat until it becomes moveable....once moveable....detach the spout.....dry out and remove any foreign matter from the connection side on the faucet...then apply a small amount of faucet grease to the connection threads and the inside barrel....a thin even coat ...excess grease will clog your aerator...don't use too much....now repeat the cleaning and lubricating process on the removed spout connector....reassemble.....remove aerator....turn on the water and flush....replace the aerator....turn water on full blast....check for leaks and for swing...it should swivel now ....if not...loosen the connection nut a tad and try again....if still no swing....you are missing a friction ring somewhere in the connection and it needs to be replaced before you will be able to swing the spout.....good luck...
Price Pfister... • Answered on Dec 04, 2017
water is supposed to come out of your faucet...in a controlled fashion....if its at the handle....remove the handle and locate the source....tighten the packing gland or replace a seal. if it sprays all crazy at the spout...try unscrewing the little piece on the tip of the spout (aerator)....flush your faucet by running the water with it off...then flush out the screen on the aerator and re-attach it...hope I was some help....good luck and always know where and how to turn your house water supply off before working on any pressure points on your water supply system.
Price Pfister... • Answered on May 23, 2016
there may be garbage in the strainer. unscrew the strainer where the water comes out and check the screen inside there. it could have a partial blockage
Price Pfister... • Answered on Aug 17, 2015
HI, parts can be found from amazon (entire assembly too), take a look here: Amazon com price pfister marielle kitchen faucet parts. Wish you best of luck. Cheers
Price Pfister... • Answered on Jan 06, 2015
Either you didn't seat the o rings properly or they are the wrong size or the cartridge needs replacing
Price Pfister... • Answered on Jul 18, 2014
LOOSE PIPES ARE WATER HAMMER.
Price Pfister... • Answered on May 30, 2014
YOUR WATER PIPES ARE NOT FIRMLY MOUNTED,IF A PIPE MOVES IT WILL MAKE NOISE,NO MATTER WHAT FAUCET YOU HAVE.
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Price Pfister... • Answered on Mar 06, 2014
Two things spell trouble for these poorly engineered units:water and thick soap...
Inside these pumps is a metal ball for
the check valve. any water in your soap
will corrode this ball, causing the pump
to lose it's prime...
Using soap thats too thick (like Dawn)
will cause the soap to harden around the moving parts and impede the pumping
action. Try a thinner soap, such as inexpensive pink hand soap.DO NOT
ADD WATER! (See above)
Hope this helps.
Price Pfister... • Answered on Nov 18, 2013
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
202 questions posted
Top Price Pfister Plumbing Experts
john h
Mike
Michael Thomas
Michael Thomas
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Price Pfister Plumbing
Most Popular Question
price pfister soap dispenser will not
  • Plumbing
