This a 7 port usb2.0 USB hub. You can connect 7 usb devices at a time but that will reduce/freeze the system performance if used together. Download speed can't be increased by this device anyway.
It's designed by Toshiba but manufactured by HannStar the part number for the motherboard is DA0TZ2MB8X0 (where "X" is the revision code) you will need to disassemble your laptop to see which revision you need, it can be A,B,C...), so far i have seen up to revision "D"
The bios chip is located close to the center in the top section of the motherboard and there is a "U1" mark close to the chip, the chip manufacturer is Windbond part number is 25X80VSIG.
Remove the four rubber bungs at each corner of the screen cover then remove the four screws. Luckilly Toshiba have thought about this problem! If you offer the ninges up to the side of the screen, you will see how it is fixed. Remove the covers fron the underside and the hard drive unplugs WITH CARE! Unscrew the suround screws from the base and remove the top cover. You can leave the keyboard in place. You will see where the hinges fit to the base. Replacement is the reverse. Hope that helps.
Some pc stores claims that they can do it but the cost is high and with a small extra amount of money you can by a new and better one pc. So my suggestion is no and believe me i searched for mines a lot.Hope that helped!
Your model number is wrong. It is P505D-S8936. The -S8935 should be the right one. Double check.
Paste this link as all one line in your browser: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2351123&rpn=PSPF0U&modelFilter=P505D-S8935&selCategory=3&selFamily=1073768663 (Hint: Copy and paste into notepad, make it all one line, then copy it to your browser)
