I dont see a s video connection on this model to connect to my PC. I have a Dell Inspiron laptop.
SOURCE: how connect Panasonic TH-50PX75U to PC?
You have to have a couple of things to make this work: 1) a PC with DVI or HDMI output, 2) a video card capable of 1280x720 resolution and 3) a video card driver/utility capable of correcting for overscan.
I have my laptop connected to one of the HDMI inputs via a DVI-to-HDMI cable. I have Windows at 1280x720 resolution on the DVI port (the external monitor). I set this through Control Panel-> Display. Once I did this I was able to see my PC desktop on my TV. The only problem then was the desktop was cutoff on all side. To fix this it was a bit more of an adventure and this solution would only work if you have an ATI Radeon video card.
I installed ATI Catalyst Control Center (CCC). In CCC, it recognized that I was connected to a Panny 50" plasma. Than enabled the DTV settings. Under those settings I put the video card into 720p@60Hz mode. I then had to create a custom format to shrink the screen to fit my Panny display. I then saved this as the default setting for the Windows desktop. Whenever Windows boots it runs CCC and sets this setting for me.
I hope that helps! It can be done and it looks great.
SOURCE: connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
SOURCE: PANASONIC PLASMA TC-P50C2 The tv
Hello
Your TV is in warranty period I thinks. If so, company is liable and will repair it free fo charge. There is "repair,replace, refund gurantees. Your gurantee card and broshure will tell you that. Look at it.
For what you are going to take the risk.
