Cars & Trucks Logo
Anonymous Posted on Jan 16, 2013
2000 gmc sierra 1500 blow hot air but the air is in the dash not coming out of the vents, why?
Heat is in the dash board not coming out of the vents.
Stephen
Level 3:
Top Expert:
  • GMC Master 21,873 Answers
  • Posted on Jan 16, 2013
 Stephen
GMC Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6210435
Points
67230
Usually a sign of a faulty blend door.
The blend doors direct air thru the heater core and out thru the vents.
  • KodyKathy Wheatley Dec 02, 2014
    how do you fix the blend door . i get hot air out my other vents except the very front ones , how do you fix it?
  •  Stephen
    Stephen Dec 02, 2014
    It depends on what the actual problem is. It could also be something blocked in the vent. If the problem is a blend door, you usually have to replace it. Sometimes the door motor dies, and sometimes the door hangs up in the box.
5 Related Answers
Bobocop
  • Posted on Dec 02, 2008
SOURCE: 2000 GMC Sierra 5.3 Litre, won't blow hot air
I experienced the same head ache. First attempt was to replace the thrmostat and after taking it apart I realized that there was nothing wrong with it. I then removed the plastic cover/panel located under the dash board on the passenger's side. (only a few 4-5 smalls screws) Removal will enable you to see the on/off switch/gate moving/rotating as you turn the knob to hot or cold positions, on the control panel. If that switch/gate seems to work ok, then the trouble is within the heater core. Many mechanincs suggested that I replace the heater core. A very expensive proposition.
I checked the heater core supply/intake hose and found it hot to the touch, while the return hose was nearly cold. It was definitely a heater core blockage. I removed both ends (supply and return) hose connections/clamps. They are located near the fire wall in the engine compartment. A special tool is very helpful to remove those clamps easily and to replace them as well. It can be done the old fashion way but this tool was a life saver and reduced work time to just minutes. (Tool is $70.00 bucks at auto parts store,so I borrowed mine from a mechanic/friend)
I then hooked up a garden hose to the return end of the heater core and reversed the flow of coolant/water through the heater core. My truck is a Sierra 2000 and I refuse to see how a heater core could get clogged up with clear coolant alone. To my surprise a flat piece of rubber about the size of a quarter blew out of it and the flow of water became unobstructed. I reconected the ends of the hoses to the heater core, replaced the lost antifreeze & everything returned back to normal. No money spent for something most mechanics suggested I replace control valves/switches ($280.00) replace heater core ($500.00) etc etc. I am glad I was curageous enough to tackle this myself and save a few pennies. Good luck, and I hope this will work for you.
Anonymous
  • 607 Answers
  • Posted on Mar 30, 2009
SOURCE: a/c and heater only blow air out of defrost
sounds like there is a vacuum leak, possibly under the hood.. Vaccumm is needed to change the mode doors.
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on May 30, 2009
either a vacumn pipe is broken or the ends split so its not passing a vacumn to open the flaps,where they are and how to get to them i cant help because i have never worked on one as they are not here in spain.check the engine end first though .Look for some small rubber pipes running from the inlet manifold
Anonymous
  • 6 Answers
  • Posted on Sep 09, 2009
SOURCE: 2000 gmc sierra 1500 5.3 v8. a/c heater control problem
your heat/cool and vent selection options are controlled by engine vacuum through small clear tubes attached to the rear of your climate control interface. Other vehicles have small steel pull wires that operate the desired changes. You might try removing the trim and any fasteners affiliated with the interface/console. GENTLY pull outward and look to see if any of these tubes are pulled off or cut/damaged. Did anyone recently install a new stereo in the vehicle? If so, the vacuum tubing and or pull wires that change your outlets could have been damaged when the stereo unit was pushed into place. Hope this helps
Testimonial: "Very good information. THANKS!"
Anonymous
  • 172 Answers
  • Posted on Jan 07, 2010
SOURCE: 2005 GMC Sierra 1500 - heater blows, but only cold air
Check coolant level. Check for heat at the heater hose going from water pump to heater core at firewall. Check to see that cable is moving coolant control valve from the closed to open position. Low mileage so it shouldn't be plugged heater core.
Testimonial: "You were absolutely correct. Low coolant level. Put in some 50/50 and we're nice and toasty now, but need to find out why coolant was so low. Thanks."
Air blowing
Usually a sign you have a blend door that is stuck, or the controller has failed. The blend doors use small electric motors controlled by the main controller on the dash.
Why is there hot air coming from my vents all the time?
well in chevy's this is normal just put it all the way on the cool side to make it less heat on you.
1helpful
My a/c work but sometime it blows hot on the left side only it
Probably your left temp actuator failed internally. Check the right instrument panel junction block-right side, end of dash-to make sure connectors are fully seated. But thisis usually caused by a faulty temp actuator.
6helpful
2answers
Heat will stay on high until turn engine off and back on
check dial switch, check valve that lets water run through heater core
Poor functioning A/C in 2004 GMC Sierra 1500
Have the engine fans and relays checked. If the engine fan does not come on when the a/c compresser kicks in then the air that comes out the vents will be warm.
1helpful
A/c and heater only blow air out of defrost
1helpful
2answers
Blower fan not working correctly
I had the same problem. There is a filter down under the passenger side of the dash that clogs up and stops the air from blowing out any of the vents. I removed the filter completely and now it blows like new.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
