RIM BlackBerry 7250 Logo
Walter Neeser Posted on Nov 12, 2012
JUM Error 529
When I turn it on, the JUM Error 529 comes up, with a continue bar; I push the wheel, and 'Data Abor .... and Reset comes up; I push the wheel and the error cycle begins again with JUM error 529
5 Related Answers
natas123
natalie trahan
  • 46 Answers
  • Posted on Feb 10, 2008
SOURCE: blackberry pearl
Problem After typing an incorrect password ten times and restarting the BlackBerry smartphone, JVM error 513 appears.
Cause All the data and applications have been deleted on the BlackBerry smartphone.
Resolution Reinstall the BlackBerry® Device Software on the BlackBerry smartphone and restore the data from a backup file (if available).
Link to the software download site of blackberry
https://www.blackberry.com/Downloads/entry.do?code=A8BAA56554F96369AB93E4F3BB068C22
Anonymous
  • Posted on Jul 20, 2008
SOURCE: how do i reset my 7520
ok i think this is how you do it ok you go to options on the homescreen then scroll to security options click on general settings and then click the track wheel once scroll down to master radio reset and if thats not it try all the same process but when you get to general setting setting click the track wheel and scroll to wipe handheld one should work good luck
tnmy2000
  • 21 Answers
  • Posted on Dec 17, 2008
SOURCE: JUM ERROR 513
It is JVM error 513... This indicates all the data and application have been deleted from the device. However, not to worry as it can be very easily restored.
You will have to re-install the Blackberry handheld software and restore the data from the backup file (if available). To re-install, you have to connect the device to your computer and run desktop manager > application loader. In case you do not have the desktop manager and the handheld software, check with your service provider and these softwares should be available for download at their website.
Anonymous
  • 84 Answers
  • Posted on Feb 05, 2009
SOURCE: Blackberry 8100: JVM Error 529
This error indicates that the applications need to be reinstalled on the BlackBerry.
Follow the steps in the link below:
http://tinyurl.com/dfw6sm
If you need further assistance you can contact me at jeremy at kitchingconsulting dot com.
Anonymous
  • Posted on Feb 19, 2009
SOURCE: How to reset my blackberry?
do u have secon solution that didnt work
JVM Error 529 Continue
One of your apps is corrupted, you need to reinstall the software. easiest method use desktop manager. Dont bother clicking on backup because it will not work, all data will be lost. If data is inportant contact me there is a way.
tip
Harley Davidson Fault Codes
2005-2008
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1600 EFI Module Processor Internal Error
20. P1270 TGS Validation Error
21. P2107 EFI Module Processor Internal Fault
22. P2122 TGS1 Low/Open
23. P2123 TGS1 High
24. P2127 TGS2 Low/Open
25. P2128 TGS2 High
26. P2138 TGS Correlation Error (Twist grip sensor)
27. P0120 TPS1 Range Error
28. P0220 TPS2 Range Error
29. P0122 TPS1 Low
30. P0123 TPS2 High/Open
31. P0222 TPS2 Low
32. P0223 TPS2 High/Open
33. P2135 TPS Correlation Error
34. P2119 EFI Motor Throttle Body Range Performance
35. P2100 EFI Motor Circuit Open
36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
37. P2102 EFI Motor Circuit Low
38. P2103 EFI Motor Circuit High
39. P2176 EFI Closed Position Not Learned
40. P1514 Air Flow Fault
41. P2105 EFI Forced engine shutdown
42. P1501 Jiffy Stand Sensor Low
43. P1502 Jiffy Stand Sensor High
44. P0572 Brake Switch Low
45. P0117 ET Sensor Low
46. P0118 ET Sensor High
47. P0112I AT Voltage Low
48. P0113I AT Voltage Open/High
49. P1351 Front Ignition Coil Driver Open/Low
50. P1354 Rear Ignition Coil Driver Open/Low
51. P1352 Front Ignition Coil Driver High/Shorted
52. P1355 Rear Ignition Coil Driver High/Shorted
53. P1357 Front Cylinder Combustion Intermittent
54. P1358 Rear Cylinder Combustion Intermittent
55. P0261 Front Injector Open/Low
56. P0263 Rear Injector Open/Low
57. P0262 Front Injector High
58. P0264 Rear Injector High
59. P0562 Battery Voltage Low
60. P0563 Battery Voltage High
61. P0501 VSS Sensor Low
62. P0502 VSS Sensor High/Open..
63. P1356 Rear Cylinder No Combustion
64. P1353 Front Cylnder No Combustion
65. P0444 Purge Solenoid Open/Low
66. P0445 Purge Solenoid High
67. P1475 Exhaust Actuation Position Error
68. P1477 Exhaust Actuator Open/Low
69. P1478 Exhaust Actuator Shorted/High
70. P0131 Front Oxygen Sensor Low
71. P0151 Rear Oxygen Sensor Low
72. P0132 Front Oxygen Sensor High
73. P0152 Rear Oxygen Sensor High
74. P0134 Front Oxygen Sensor Inactive
75. P0154 Rear Oxygen Sensor Inactive
76. P1510 EFI Limited Performance Mode
77. P1511 EFI Power Management Mode
78. P1512 EFI Forced Idle Mode
79. P0577 Cruise Control Input High
Source
http://moto-files.weebly.com/harley-davidson-dtc.html
on Dec 20, 2016 • Cars & Trucks
I droped my phone in the toilet now when i put the batterie in it says jum error 517 & reset . tired to reset it but it wont work ?
Take the battery out and let the handset dry out, this will take a day or so, then replace the battery and power the handset up. If the error/issue continues, the you will need to replace the handset. If you have insurance, then you can file a claim and at&t will bill you for the deductable.
I got the error JUM 102 with the word RESET below it,i wanna save my DATA
Unfortunately this Java error has no fix other than to reset/software update the handset, you will lose your information. There is no way around this...
The screen says JUM Error Reset. What do I do? I was charging the phone and when I unplugged it this is what the screen said. Push to reset it and the screen shuts off and comes back on with the same...
oof. JUM= oh ****. What JUM error code is it?? With the phone on pull the battery out. I doubt that will do anything but it's the easiest and what do you have to lose ?? And when that doesn't work download a program called JL commander and wipe the phone clean, re-install the OS. Hope you backed up your info
JUM Error 513
Remove the battery from the phone and put it back in after one minute.
the phone will automatically reboot
2answers
Msg when off... "Data Abor... Reset"
Download the latest handheld OS for your BlackBerry
- wipe out the BB using JL_CMDER
- reload the OS
- don't play with themes
3helpful
Screen shows JUM error 182 reset ???????
Upgrade to BlackBerry Device Software 4.0 Service Pack 2.
Complete the following workarounds until the problem is resolved:
1. Perform a hard reset on the BlackBerry device.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
2. Delete and reload the data on the BlackBerry device.
  1. In BlackBerry Desktop Manager, open Application Loader and click Next.
  2. Verify the correct applications are selected and clickNext.
  3. Click Advanced.
  4. Select the option for Erase all application data and Erase all currently installed applications and click Next.
  5. Click Finish. The data on the BlackBerry device is deleted and reloaded.
1helpful
How do i reset my 7520
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
