Husqvarna 128LD 28cc 2-Stroke Gas-Powered Straight-Shaft String Logo
RonC Posted on Oct 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My husqvarna 128ld won't start
Plink-plonk
Level 3:
  • Husqvarna Master 1,807 Answers
  • Posted on Aug 02, 2013
Plink-plonk
Husqvarna Master
Level 3:
Answers
1807
Questions
Helped
818719
Points
15648
Do you have compression, good spark and is fuel getting into the cylinder.?
Husqvarna trimmer 952-711953 128LD starts but does not stay running
Hi Jim-
I found these youtube videos regarding repairs on Husqvarna 128LD trimmer. The 128CD and 128LD have the same engine.
https://video.search.yahoo.com/search/video;_ylt=AwrDQ2rlht5dlVwASpX7w8QF;_ylu=X3oDMTBncGdyMzQ0BHNlYwNzZWFyY2gEdnRpZAM-;_ylc=X1MDOTY3ODEzMDcEX3IDMgRhY3RuA2NsawRjc3JjcHZpZAM2bktaclRFd0xqRXlpaEVKWGFfVmpnSmtNall3TUFBQUFBQzkxU09vBGZyA3lmcC10LXMEZnIyA3NhLWdwBGdwcmlkA3lkbEI3RXRtUlVDbm5IVUxhd0dDakEEbl9yc2x0AzYwBG5fc3VnZwMxBG9yaWdpbgN2aWRlby5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzM1BHF1ZXJ5A2h1c3F2YXJuYSUyMDEyOGxkJTIwdHJvdWJsZXNob290aW5nBHRfc3RtcAMxNTc0ODY5MDMy?p=husqvarna+128ld+troubleshooting&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yfp-t-s
Hope this helps.
Hi Jim-
I also found this link regarding owners manual for your Husqvarna.
Drive head rotates counter-clockwise. Can't get it back into position. Use to be able to simply turn it back around. Can't now.
Husqvarna 128 LD Weedeater Repair Questions,... - Fixya
www.fixya.com > Forum > Lawn Trimmers & Edgers > Husqvarna
Recent Husqvarna 128 LD Weedeater questions, problems & answers. Free expert DIY tips, ... Drive head rotates counter-clockwise. Can't get it back into ...
HOW TO CHANGE HEADS ON HUSQVARNA 128LD - Fixya
www.fixya.com/support/t20975899-change_heads_husqvarna_128ld
Oct 25, 2013 - Question about Husqvarna 128 LD Weedeater ... SOURCE: MyHusqvarna 128LD primer bulb .... Drive head rotates counter-clockwise.
Weed eater bogs out at full throttle - Fixya
Husqvarna 128LD Starter Recoil Issue
Here is the complete Illustrated Parts List. It has exploded views of the whole strimmer.
Husqvarna Trimmer 128LD starter card will not retract
Check the recoil spring in the starter housing, sometimes the rope rotor can jump out the hook on the spring.
Husqvarna 128ld won't start
May have an air leak in the fuel line, primer bubble could be split or the primer bulb base is blocked.
My husqvarna 128ld starts and idles fast but only with the choke half on. Give it gas or take the choke off and it dies.
Possibly a fuel starvation issue, incorrect fuel air mix or an air leak within the fuel system
1helpful
My Husqvarna 128LD pull cord doesn't engage
Possibly the recoil starter pawl's on the inside of the recoil housing not engagning with the flywheel.
3answers
My Husqvarna 128ld trimmer will run but only at low rpm. I cant find a tool to adjust the carb. If I choke it 1/2 it will run at higher rpm, I suspect a fuel problem. It started in an instant.
If it is a newer trimmer it has a little plastic deal on the adjustment screws to prevent adjusttment.(epa). You have to break that off then a screw driver will work. Some are tough, turn hi speed screw counter clockwise it will rev
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
