SOURCE: Battery?, wiring??
If your Alternator didn't charging the battery, even though you brand new battery will not last. So there is two possible cause, 1) Your Alternator is not functioning. 2) there is a wiring problem that causing your battery to discharge easily, but you check it after you switch off the key remove the battery negative terminal then touch it back to batt term. and see if there is little blue spark, if does your wiring system got problem. If not, so your Alternator do not charge the battery.
SOURCE: mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
SOURCE: Husquavarna tractor battery won"t start engine
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
SOURCE: Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
SOURCE: Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
