My phone is saying unregistered SIM. I purchased a 3 month plan at the end of Jan. Or beginning of Feb. And I should still have 57.94 minutes left. My serial # is 013 854 002 826 605. What is going on??My phone is saying unregistered SIM. I purchased a 3 month plan at the end of Jan. Or beginning of Feb. And I should still have 57.94 minutes left. My serial # is 013 854 002 826 605. What is going on??
AnonymousMar 16, 2014
I have had my phone for three years and now it says unregistered sim cardI have had my phone for three years and now it says unregistered sim card
You can't post conmments that contain an email address.
If you did not insert a different SIM card in your mobile phone, then the SIM card may have developed a fault or the SIM card has run out of credits and needs to be re-charged. I suggest you contact Optus to sort out this problem.
My name is Bhargav motorola v3 mobile purchase in amerika but my home in india (gujarat - surat) my motorola problam in not support all sim mobile on to display error in unregister sim please my problem soll my contact no 9016893902 Thank You sir
hi, You will have to make sure the battery and sim card are both properly placed.This means the sim card should fit perfectly into it's slot and the battery has to lap over it perfectly as well. If this does not work then you may try using another sim card in the phone or you try using the sim on another phone to check if it is the sim that has the fault. most of the time it is either the sim is not properly placed or the sim card is gone bad.
is it an unlocked phone?
The "Unregistered SIM" message means that you're using a SIM card for which this phone is not intended. You will need to have the phone unlocked and it should work.
If it is a new fone thenPhones are not shipped activated. You should look in the box for activation instructions. Read and follow them. is that a prepaid sim then probably the sim has been deactivated...
If the phone is saying unregistered sim It basically means that the sim card has either not been activated at all or has not been activated to be used with that handset... Simply contact your carrier and they should be able to asess the situation over the phone
Tis link will show you how to unlock your phone. Make sure that you change the SIM lock code to 0000 first. http://www.mobile2mobile.net/unlock/RemoteunlockingMotorola.htm
