Question about Motorola Mobility RAZR2 V8 Cellular Phone
Whenever SIM is inserted in Handset it shows "UNRegistered SIM" & that SIM works on all other Mobiles.
Posted by anandm776 on
Anonymous
    Scholar:
  • 83 Answers
Is it an unlocked phone? The "Unregistered SIM" message means that you're using a SIM card for which this phone is not intended. You will need to have the phone unlocked and it should work.
If it is a new fone then Phones are not shipped activated. You should look in the box for activation instructions. Read and follow them.
is that a prepaid sim then probably the sim has been deactivated...
Posted on Jun 15, 2010
Insert sim
Maybe your sim is expired. Try inserting your sim in another mobile that's really working.
Nov 03, 2013 | Motorola Mobility RAZR V3
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
Motorola v8 when insert Airtel or Uninor Sim it shows Unregistered Sim. and when i insert Vodafone Sim it works. please solve my problem thanx R B CHARY
Your Phone is locked on to Vodafone and so must get this unlocked with the help of the unlocking code. so call up vodafone call centre and ask them if the time limit is up of one year to unlock your phone. Mentione the IMEI code on your phone along with the purchase details.
Sep 16, 2010 | Cell Phones
Sim invalid, it is inserted correctly in sim 2,
if you r using korean/ china made mobiles then if u got only one imei no then the other will be rejected
check ur imei by pressing *#06# in your handset
Dec 27, 2009 | Cell Phones
My v8 shows unregistered simand i cannot use it i need instant solution
If the phone is saying unregistered sim It basically means that the sim card has either not been activated at all or has not been activated to be used with that handset... Simply contact your carrier and they should be able to asess the situation over the phone
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Dec 17, 2009 | Motorola Mobility RAZR2 V8 Cellular Phone
Unregistered sim.
your handset is barred from the network,
you can use cellc like you are, OR
you can take it in to a repair shop and have them fit you a new pcb
Jun 11, 2009 | Motorola Mobility RAZR2 V8 Cellular Phone
How to make caller names show when contacts are in with name and number
Make sure your contacts are saved to the handset not the sim
this is because nokia handset only read the name and number from the handset when you get a call
so copy your contacts to the handset and this should work
Any Problems Contact Me On [email protected]
Michael (Mobile Phone Engineer)
Universal Mobiles Coventr LTD
May 28, 2009 | Nokia 6210 Navigator Cell Phone
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Motorola Mobility RAZR2 V8 Cellular Phone Logo
495 people viewed this question
Top Motorola Mobility Cell Phones Experts
Watching Him
Watching Him
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
