2000 Cadillac Catera Logo
Posted on Sep 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2001 catera out of the blue stopped running. I changed the crank shaft position sensor . I have been told it could be the gas cap preventing it from starting. the code P0455 comes up
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 76 Answers
  • Posted on Sep 17, 2012
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
76
Questions
Helped
24678
Points
226
VOTE FOR ME INFORM ME OF YOUR PROGRESS
P0450 Evap Emission Ctrl Sys Pres Sensor Error
P0451- Evap Emission Ctrl Sys Pres Sensor Range/Perf
P0452- Evap Emission Ctrl Sys Pres Sensor Lo Input
P0453- Evap Emission Ctrl Sys Pres Sensor Hi Input
P0454 Evap Emission Ctrl Sys Pres Sensor Interm
P0455- Evap Emission Ctrl Sys Gross Leak Detected
P0456- Evap Emission Ctrl Sys Very Small LeakDetected)
P0457 Evap Emission Ctrl Sys Leak (fuel cap loose/off)
P0458 Evaporative Emission Sys Purge Ctrl Valve Circ Low
P0459 Evaporative Emission Sys Purge Ctrl Valve CircHigh
P0460- Fuel Tank Level Indicator Circ Error
P0461- Fuel Level Sensor Circ Range/Per
P2408 Fuel Cap Sensor/Switch Circ
P2409 Fuel Cap Sensor/Switch Circ Range/Perf
P2410 Fuel Cap Sensor/Switch Circ Low
P2411 Fuel Cap Sensor/Switch Circ High
P2412 Fuel Cap Sensor/Switch Circ Interm/Erratic
Stephen
Level 3:
Top Expert:
  • Cadillac Master 21,873 Answers
  • Posted on Sep 18, 2012
 Stephen
Cadillac Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6210521
Points
67230
Code 455 will not keep a car from starting.
The code means the computer has tried to vent the fuel tank and found a large leak which is often a loose or missing gas cap.
Someone will need to figure out if you are dealing with a spark or fuel issue to proceed.
5 Related Answers
Anonymous
  • 42 Answers
  • Posted on Mar 11, 2009
SOURCE: crank sensor
Yes your crank sensor tells your computer when to fire the injectors and the spark plugs so, if you have no crank sensor, you have no start. It could prevent your car from starting depending on the conditions when the security system was activated. Has anyone kicked the rear of your car lately? Or have you been in a fender bender? Those 2 things could trip the inertia switch in the fuel pump which could also cause your car to not start like that.
Anonymous
  • 124 Answers
  • Posted on Mar 12, 2009
SOURCE: 98 Cadillac Catera, Cranks but not starts.
could be crank or cam sensor
Anonymous
  • 135 Answers
  • Posted on May 19, 2009
SOURCE: Need to replace both crankshaft position sensors 2001 Cadillac
4.6 the twocrankshaft position sensors are located on the front of the block just above and to the left of the oil filter. not hard to replace.
Anonymous
  • 4 Answers
  • Posted on Aug 04, 2009
SOURCE: gas tank won't open, trunk won't open, radio stopped working, left tail lamp won't work
It's the body control module. It's located under the dash to the left of the steering column. I had same problem, went to the junk yard and bought one and the problem went away. Dealer wants $600.00-700.00 for the BCM, I paid $30.00
Anonymous
  • 1627 Answers
  • Posted on Jul 15, 2010
SOURCE: how do i fix my 2001 cadillac catera idle problem
The problems you are describing indicate to me that you likely need to replace the coil pack that runs from the spark plugs ,and the plug wires end up at it.It also may be the spark plug wires,get a water bottle and spray the wires after dark and if you get a light show from them then replace them,if not,replace the coil pack.
1helpful
3answers
It started dying only sometimes, if you let it set 5 min or so it will start again. Drive it all day runs great then pull into parking lot or stop sign and it dies. Turns over fine but does not fire....
The Catera has a history of stalling/cutoff issues. Many are solved with the replacement of the crankshaft position sensor. It does give the symptoms you describe. I would try that first as it is fairly cheap and easy to replace. If the problem persists after that, you've at least removed one potential possibility.
25597730-01vm304gptfsbcx1qe0tia2u-3-1.jpgThis is the description of the crank sensor from AUTOZONE (cost $44.99 USD)
  • The crankshaft position sensor identifies position of the crankshaft to the ignition control module (ICM), engine control module (ECM) or powertrain control module (PCM)
  • When not replaced, vehicle may experience no start, hard start, intermittent engine shut down, misfire, engine cut out, excessive fuel consumption, CEL illumination and/or failed emission test
  • Proper alignment, positioning and spacing for faster, easier installation
  • Designed to meet or exceed OE specifications in form, fit and function
Will not crank
Tps has nothing to do with sparks. If you had sparks going to the distrubuter but none coming out, the cap or rotor is not installed correctly.
3answers
Car stopped running while driving
run the fault codes and check for cam/crank position sensor . check that the cam shaft is turning (broken cam belt)
2003 Nissan xterra...couple problems...timing belt just changed...knock sensor, crank shaft positioning sensor, distributor cap all changed...service engine soon light keeps coming on...took to...
Had same issue with (re: crank position sensor) on a 2002 Kia. Had all the same work done as you, only to find out with was one of those Kias with a manufacture defect in the block where the crankshaft keeper key slots to lock crankshaft in place in block. The block half of the slot had worn and the crank shaft itself kept slipping out of time. Is it throwing any codes? Gas pedal linkage may well just need a good cleaning and lubrication.
2helpful
2001 CADILLAC CATERA CAR JUST DIES LIKE OUT OF GAS AFTER 1/2HR OR SO WILL RUN FOR A FEW MILES THEN DIES AGAIN IF LEFT OVER NIGHT WILL RUN FOR 30 OR SO MILES BEFORE DIEING FUEL CAP LIGHT WIL COME ON DASH
it sounds alot like the cranshaft position sensor (cps)
i had the same problem with mine, i very common problen with the catera's
hope this helps
3helpful
2answers
The engine stops running after 10 minutes of driving
could be a bad crank sensor, a bad crank sensor will let car run for a while then shut down and will not start for 10 to 15 min. and it will repeat this cycle if not fixed.the crankshaft position sensor provides the ignition module and pcm with a crankshaft position signal. the module uses this signal to determine spark for each cylinder. the pcm uses this signal for proper timing of engine.
2answers
Enging light on
crank shaft sensor or cam sensor
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
