I took out the mother board and then put it back in. The computer starts,the hard drive light comes on then goes off. The fans stay on but the computer will not boot up.
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
SOURCE: emachines 1900+ gets power to the monitor and computer but wont boot
I am having exactly the same problem also (I have a Model C2685). The hard drive and CD ROM Drive light comes on and stays on. Thanks for any advice.. i turn on the computer and monitor.the monitor powered up the computer fans came on even the cpu fan but wouldnt boot not even a flicker on the screen. the hard drive light comes on and stays on. ive tried a new power suply,new ram,and a new hard drive. anny help would be awsome thanks
SOURCE: weird hard drive won't boot
Try putting it in and loading an OS onto it directly (Install XP Pro or whatever you have handy). Let the machine do the disk work fo you. See if it will boot that way. If it does, then you should be able to copy off the important files by hooking the old one up as a slave. It's a pain in the rear, but sometimes it's better to start with a fresh install of the OS.
SOURCE: HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
SOURCE: Computer won't boot up after attempting to install new memory
I believe resetting the CMOS would fix this problem. To reset the CMOS, open up the computer and locate a battery similar to this one (it's on the motherboard):
Once you find it, pull it out. Leave it out for about 24 hours (one day) afterward placing the battery back into its slot on the motherboard. Now try booting up.
It should now successfully start up requesting that you make changes to the BIOS since the CMOS was just reset. Afterward you should be able to use the computer normally.
NOTE: Try resetting the CMOS with the original RAM inside the computer. The new RAM might be forcing the motherboard to send too much voltage or use an incompatible Mhz setting to support the new stick of RAM.
Let me know how it turns out and if I can do anything else to assist you.
