SOURCE: Converting to a Booster Seat.
Better yet, please use this manual for clear instructions and dont forget to leave a rating for me. Thanks!!!
http://www.coscojuvenile.com/instructions.asp
SOURCE: Need to Re-Assemble my Graco Snug Ride Car Seat
Hi jessibee
I found the site that you need to get an instruction manual for the seat. You will need to find the exact model of the SnugSeat that you have, because there are quite a few to choose from.
to find the model/serial number...
Car Seat
Toddler or Booster - On the back of the car seat OR on the bottom of the seat
Infant - On the back of carrier OR on the bottom of carrier OR on the stay-in-car base
Thanks for using FixYa, a Fixya rating would be great for this advice.
Good luck.
regards
robotek
SOURCE: Manual for a car seat
First set the harness together at the chest clip and the **** buckle. Then slide each shoulder strap through at the best height for your child. For a forward facing seat , it should be at or above the shoulders. Once both shoulders are passed through, there is a Tshapped metal flat piece, each belt slides onto that. That is 2 of the 4 ends of the straps squared away. The bottom 2 , you slide through the holes in the car seat, through the holes in the shell of the seat, and then pull to ensure they are in tight. Thank you!
SOURCE: Graco Snugride Infant Car Seat
HI! I've had 3 babies and alwyas use the Sungride! My presonal trick......First, be sure to roll up a towel (try different sizes for the perfect fit) and push it under by the seat crease (where the back cushion and seat cushion meet). Then, when you are pulling the belt to make it tighter, put your knee in it to add some weight and really get it tightened! I'm sure you'll notice a world of difference! :)
SOURCE: Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
Also check out the info in this link on the Gracobaby website:http://blog.gracobaby.com/2013/02/25/tip...
