My SD card is stuck in the camcorder and I don't just want to rip it out. Any idea of what I can do?
SOURCE: Panasonic SD Card reading problem
Yes. The device was not using a standard file system. There usually is no cure. Try this. Format the card in the device and try one more time. Many don't know to perform this step.
SOURCE: Panasonic camcorder
I'm no expert, but I don't think you can do that with just the video camera alone. First you'd have to pass your video onto a computer using dv motion studio and then you can put that output file onto a sd card. I don't think it would be possible to play that video off the card on the camera. Hope that helps
SOURCE: Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
SOURCE: Can you record video to the SD card on the Panasonic NV-GS25?
Yes very easy with a razor sharp knife you will need to cut it in middle.
When you did that you will have this [ ] [ ] if you put in the right part you will record video to sd card and the left side will put pictures on sd card , when ur done just put them together with some tape again and same thing next time
SOURCE: I have a camcorder Panasonic SDR-T55 and want to
You may not have that option.Most camcorders give you the option to either record to the built in memory or the SD card Flash Memory.The option to copy from the internal to SD card is device option. You can use USB, AV , cables to convert files to DVD or other formats to copy to Flash Media or DVD/ VCD/DVD RAM.Good Luck.
