Close to the bottom in the corner near the motor stator (= electric field) between the machine housing and the stator there is a narrow metal strip connection point visible which makes contact with the metal outer surface of the stator, the strip sits against the corner on the underside between the motor stator and the machine housing from the front so pushed to the back comes out so at the contact side of all sliding contacts you will see are that part, I myself always recommend letting eight jure the capacitor because it only makes sense for radio interference suppression only at work places.
It needs to be put up between plastic housing and field/stator.
