The bars of light, (red to yellow) show #1 problem, the first red bar continued flash. #2 problem, it switches to two red bars but I have not counted the flashes. #3 problem, an upper, 3rd red bar flashes a few times, pauses and begins again. I need to know all signals to cope, since repairs on "old'" not done at repair venue. All signals show up sporadically, and it runs goo d and has normal lights most of the time
SOURCE: i have a quicky power chair, i think its an F-35 b...
I think you have locked your controller, or put it in "sleep mode". Turn on the chair again and push the joystick forward, then to reverse, then forward again and release. It should fire up. Let us know if that worked.
SOURCE: I have a quickie electric
The right motor will need to be replaced. What reason did they give why Meduicare wouldn't pay for repair If the Aspire is your only chair then Medicare will pay. If you have received a new chair since the Aspire then Medicare will only pay for repair to the newer chair. You can contact a repair service other than the home Medical to get the chair fixed. You can contact Roadrunner Mobility @ 1-800-467-2668 for repair Hope this helps you
SOURCE: My suns Quickie P320 (dual battery) requires very
do a load test on battery;'s first to verify batterys r good if they r then check ur battery connections 1 of them is probaly bad i just whent thru this same problem
