It shows 79% charge, not charging
If the charger cannot charging is the problem,then you need to repair
the Battery management software,because you say that the battery is
working,then the error should be on the software,that it doesn't
indicate that the battery is charging,first go to Device Manager (Right
click My Computer,select Properties,click Hardware,click Device Manager)
by type "Device" on the start menu and select Device Manager
Expand the Battery categories and right click on Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
On the Device Manager taskbar, click Scan for hardware changes
Please let me know if it's working
SOURCE: Lenovo N100 does not switch to battery power
Batteries have a memory,
When the battery was new it most likely would run for 1.5 hours, but, since you didn't want the computer to go off, and you were by a plug-in, you plugged it in before it was completely or maybe sometimes not even halfway discharged. That is where it stated its "memory" - this got shorter and shorter = your battery "THINKS" it is totally discharged and reads as so.
There are programs on the web (can't advertize for pay programs or give you links to them - against the rules) - that will re-vitalize your battery to almost new condition by discharging it more and more till it is truly fully discharged, then will fill it back to like new charge time.
Or you can buy a new battery.
SOURCE: battery problem
hi monica
you have to get your battery replaced as the battery for this particular series konks off after a year or so.You can buy original battery from us which is expensive or you can buy "Amigo Inc. USA'' battery for the same model which works absolutely fine with this particular series.If u want we can give you our dealers address in your city.
regards
Maninder
SOURCE: lenovo y410 graphic card
If you want just adjust your display settings, then right click on empty desktop and choose properties -> settings, but if you wish to update graphic drivers, then here you can find drivers for your Lenovo.
Best wishes,
Chillimar
SOURCE: lenovo y410 notebook not starting by light and battery.
hi,
This iue might be with RAM only so please open the chamber on the bottom(after checking manual,there will be two screw only) and once refix it.If not then get it checked by any hardware expert.
SOURCE: activateing camera in lenovo Y410 after driver installation.
plz remove all ur camera drivers and then
remove the program USB video device and restart ur laptop and press fn+esc for 2 times after restarting it...........and then insert ur motherboard cd ....it will install the driver automatically
plzzzzzz vote for me
