Roketa 150cc cheap Scooters Logo
Posted on Jul 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 150 cc motor scooter won't start
I think it is a carb problem it seems to choke itself out but not w/the choke(?).
Anonymous
Level 2:
Sergeant:
  • Expert 186 Answers
  • Posted on Jul 29, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
186
Questions
Helped
75266
Points
522
Possible choke stuck or a sticking float
150 cc scooter motor won't start unless I use starting fluid
if it starts with starting fluid and then dies it means you are not getting gas. a lot of times it can be that the fuel line is clogged or you may need to clean the carb. take it off and clean but don't change any screw settings . you will find a very small hole in the carb. take a stick pin and make sure it is clear as well.
May 16, 2014 • Cycling
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
3helpful
1helpful
Wheres the choke on a 49cc pocket rocket
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
Scooter won't start with electric start or kick start.
  1. Try depressing the brake handle when starting.
  2. The battery has not been charged.
  3. The battery is hooked up wrong. This is often the reason for blown fuses.
  4. There isn't enough gas or two-stroke oil in the scooter.
  5. There is a gas flow problem, especially on the Euro Scooter or Yamaha models.
  6. The spark plug wire is not connected.
  7. A low battery or bad relay can cause the scooter to only start by using the kick starter.
  8. There is no spark to the spark plug. The coil is bad and needs to be replaced.
  9. Turn the key to the "on" position.
You need to check for a spark. There are a few ways to do this. The easiest way is to remove the spark plug and put it back in the spark plug cap. Then ground it to the engine - you should be able to lay it against a non-painted portion of the engine. Make sure there is good metal-to-metal contact. In a semi darkened area, attempt to start the scooter. You should see a definite spark at the tip of the spark plug. It's hard to see in direct light. If the color of the spark is blue, that means it's a strong spark. A white color is less strong, and a yellow color is weak. Most scooter starting systems are a bit weak (compared to cars). Even a yellow spark should start your scooter just fine.
The spark must occur at the right time. Just about all scooters made since around 1980 have an electronic ignition. These systems can rarely be set. In general, the spark occurs just before the piston reaches the top of it's stroke. There is a slight delay between the spark plug fire and the fuel-air mixture ignition. That's why the spark occurs a little early. Most ignition systems have an advance unit build in. As the engine speeds up, the time of the spark retards a little bit. This helps the engine fire the mixture at the proper time
There are a lot of tiny fuel and air passageways in the carburetor that must be kept clean it order for your scooter to run right. Carefully, take the carburetor apart. This can be relative easy (on a 50cc scooter). The carb has tiny passages that can get gummed up. Your scooter will not run correctly if the carburetor isn't completely clean, so take your time. I use a gallon container of carb dip (you can get a gallon at your local auto supply store).
First, remove all of the rubber and gaskets or they will get damaged. After a 20 minute soaking in carb dip, I blow out the carb with compressed air. You have to get all the jets and the passageways clean. Be sure the jets are clear, especially the starter jet. Sometimes carb cleaner won't clear out these tiny jets. Use a guitar or a piano string, a strand of copper electrical wire, or a tiny drill bit pin vise. Be sure not to increase the size of the hole in the starter jet or you'll change the tuning. Carefully reassemble everything, checking for cracks in the rubber carb boots and the gaskets. Replace them if they are old and cracked. Be sure and remove all rubber and gasket material first or they could get ruined. Spray carb cleaner also works if you're diligent.
If you have an electric choke, check it to make sure it works. Check the resistance between the wires - you should see around 10 ohms or less. Measure the length of the choke assembly. Remove the choke from the carb and plug the wires into a 12V source for 15 minutes. The choke body should be warm. Measure the length again - it should increase by around 1/8".
Next, consider whether your exhaust pipe is clogged. This is especially a problem with older two stroke scooters. The unburned fuel/oil mixture builds up in the exhaust pipe along with carbon over time. If the exhaust pipe is clogged, your scooter will run terribly or not at all. It can be difficult to tell if the exhaust pipe is clogged. The easiest way to tell is to remove it and try starting your scooter. It will be a bit loud - two strokes will sound like a chain saw. If it runs with the exhaust pipe off, you know that is the problem
hope this helps
John
Eton four-wheeler will only start for a second after I spray carburetor with carburator spray help me to get it to run
hope this helps
John
I have a JohnWay 150 cc scooter . yesterday I noticed a small knocking in the front of the engine so I checked the oil and it needed it. I put 10 w 40 royal purple in until i saw it show up at the...
there are a few things you can do first is check the fuel flow to the carb and check to see if the carb is getting fuel to do this unscrew the screw on the bottom of the carb and see if the fuel is flowing if it is remember to retighten the screw ,then you may have to reset the valves or you may be getting air back into the carb.. also remember to always keep a check on the oil level you can severly damage a motor if the oil get to low and you run it...
Top Roketa Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Tesfay
Tesfay
Kevin Cumberland
Level 1 Expert
Are you a Roketa Computer and Internet Expert? Answer questions, earn points and help others
