After change iol I follow woner manual and it hard to follow it up
1 Turn key in electronic ignition switch control unit to position " 1" 2 Press the system select button (S110s3) repeatedly until the basic display (kilometer reading display or temperature display) is shown in the multifunction display (A1p13) 3 Briefly press trip odometer reset button (A1s3) 3 i A signal tone sounds and the voltage times. display appears in the multifunction display (A1p13). 4 Press lower scroll forward/back button (S110s1) i The "Service menu" appears in the multifunction display (A1p13). 5 Press buttons + and -, setting of specific functions and volume control (S111s1) repeatedly and select "Confirmation" menu item 6 Press lower system selection button (S110s3) i "Confirmation" appears in the multifunction to confirm. display (A1p13) and the menu item "Complete service" is shown against a sight bar in the background 7 Press lower system selection button (S110s3) i "Service confirmed" appears in the to confirm. multifunction display (A1p13). 8 Press the upper system selection button (S110s3) repeatedly until the "Service menu" is shown in the multifunction display (A1p13) 9 Using the + and -buttons, setting of specific functions and volume control (S111s1) select the menu item "Special work" 10 Press lower system selection button (S110s3) to confirm. 11 Using the + and -buttons, setting of specific functions and volume control (S111s1), select menu item "Service 3" 12 Press lower system selection button (S110s3) to confirm. 13 Select the button + and -, setting of specific i "Standard oil" or "Oil quality 229.5". functions and volume control (S111s1) select the specification of the engine oil used i If only one oil quality is approved for the engine, no oil selection is possible. 14 Press lower system selection button (S110s3) i The message "Item confirmed" appears in to confirm. the multifunction display (A1p13). Copyright DaimlerChrysler AG 10/10/06 G/09/06. This WIS printout will not be recorded by the update service. Page 1 15 Press the upper system selection button (S110s3) repeatedly until the basic display (kilometer reading display or temperature display) is shown in the multifunction display (A1p13) 16 Turn key in electronic ignition switch control unit to position " 0"
Copyright
