You can download Service Manual of Behringer PMP3000 free of cost on below link:
https://www.electronica-pt.com/esquema/audio/behringer-audio/behringer-pmp3000-16040/ Behringer PMP3000
SOURCE: I would like to print out an owner's manual for
Di you mean this one? -> http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
SOURCE: europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
SOURCE: prefader listening light never goes out
The circuitry is a bit complex for that PFL light. The LED is driven by a transistor T38 type BC846 to turn it OFF by grounding out the current coming by way of teh MUTE LED or the MUTE switch (SW14) horts out the MUTE LED. There is a 1K limiting resistor from +15 volts feeding the two LEDS in series.
IF transistor T38 is open the PFL will be on. HOWEVER T38 will also be turned off if transistor T44 (BC846 type NPN) or if capcitor C90 2ufd/50v is shorted OR if resistor R253 is open OR is switch SW8 (PFL DPST )is not contacting the ground side of of the half tied to R247. If R247 is open that will also cause the PFL LED to illuminate...
AND if the signal coming in is at clippling level the PFL LED will light.
All that circuitry serves as a clip detector plus the PFL function.
Verify you are not sending clipping level into the channel first... turn the trim off. If not, you are in for major surgery as all the knobs for that section of the circuit board and the screws for the XLR's and the 1/4 inch jacks must come off as well as some support screws IF it is necessary to access the top side of the board... Maybe you will get lucky and the bad component MIGHT be on the bottom of the board.
