20 Most Recent Behringer B3031A 2-Way Active Studio Monitors Questions & Answers
No hope. I have replied to this sort of question elsewhere but Behringer are very protective of their stuff and won't even let us have diagrams. Only Behringer service. If anyone has any Behringer service manuals / schematics we would love them
Behringer B3031A... | Answered on Aug 27, 2015
i found legit looking schematics here...the pdf includes many revisions, adding to their credibility...haven't put them to the test...
http://www.electronica-pt.com/index.php/component/option,com_remository/Itemid,34/func,startdown/id,16026/
Behringer B3031A... | Answered on Apr 14, 2012
The fault is not with the speakers... It is with the noisy audio system common in computers. Get a decent USB audio interface and use balanced interconnect cables to solve the problem.
Behringer B3031A... | Answered on Aug 02, 2011
this is normaly a wiring or amp issue. if it was the speakers they wouldnt make any sound or they would crackle or buzz
Behringer B3031A... | Answered on Jan 31, 2011
This sounds like an internal failure, probably something overheating since it takes time to recover. Behringer OFTEN puts thermistors to sense temp on heatsinks that shut down in the event of overtemp.
If you are not electronically adept, best to take this in for repair. If you are able to work on electronics, try using circuit cooler to isolate the failure. First a good visual inspection followed by the finger test searching for hot components... Do use care where high voltages are involved, mainly in power supplies and input power leads, etc..
Behringer B3031A... | Answered on Nov 30, 2010
In order to help you we would need the make and model of the mixer.
Behringer Music | Answered on Apr 30, 2020
Behringer recommends using a shielded CAT 5e cable with Ethercon connectors wired to the T568B standard to connect the two. Also you need to make sure that the board is completely powered on before turning on the S32 for proper connection. Make sure you are connecting between the Aes50A ports. When connected you should be able to see a green light next to Aes50A in the main screen. Then you will need to properly route the channels.
Behringer Music | Answered on Nov 13, 2019
See if another audio source connected to the mixer produces the same results. Try with the same cable and then with another cable. The purpose of this procedure is to determine if it is the cable and/or the laptop. (Sound card problem???) or mixer.
Is it ALL audio or just specific audio from for instance, a music application? Does it cut out using iTunes?
The mixer may have a bad or oxidized input. Try a different input channel? Are you using headphones to listen? It may be the headphone amp? OR, if audio is produced via amped speakers, it may be the mixer output. Does the mixer have metering? Do the meters also cut out? Does the laptop do the same thing if plugging in headphones to the laptop directly (no mixer)?
Behringer Music | Answered on Oct 23, 2019
Behringer B3031A 2-Way Active Studio Monitors Logo
14 questions posted
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
get behringer b2031a schematic
  • Music
