All tvs in house the same
If cable etc have it looked at--line from it or a sat feed etc--could be a bad connection or a problem at the source if all sets have same issue--if I was for example using a single line coming in--disconnect it and hook it directly to a single set--if problem not there it is in the house--if there it is outside.
SOURCE: Can't watch the channel, pixcels breaking up, no
It sounds like your using Rabbit Ears or Outside Antenna. If you are your going to have to improve the signal level. If you are on cable then first call your Cable provider and have them come out and check the signal level. Then, if neither is the problem, you'll have to take it into a service center to have it properly diagnosed.
SOURCE: Insignia LCD32 digital channels are breaking up.
coax feeding that tv may be too long or bad.
Try switching tv's if possible.
Some TV's have better reception that others.
SOURCE: My TV Sharp 26 SB1 LCD PBS channel breaks up
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
SOURCE: only getting blue screen on both tvs. one keeps
New TV's or new problem? If these are new TV's it could be that they are set on something other than the Cable Input Option.
On your remote press the input button to get an onscreen menu and set them to cable.
Otherwise, if you installed these yourself recently, recheck all connections to make sure they are set up correctly, using the manuals that came with the TVs. My guess is that you may have connected them incorrectly to/from the cable input device.
If these are not new TVs and this is a new problem, take a look at your outside cable box. Occasionally one can have a problem with an input cable. If that is the case, the cable company needs to be called to replace or repair.
Thank you for using FixYa.
SOURCE: i have three tvs in
I expect the connections could be in need of attention. Check the point where they are connected via that booster. If you have a portable to test the bedroom and rule out the tuner in the bedroom TV?
Hope that helps.
