Need to know what wire is what by color
Roadmaster EA400N Wire Colors Brown - Right Signal In Gray - Right Out (-) Pink - Right Rear Out Dk Blue - Right Front Out Green - Left Signal In Yellow Left Rear Out White - Left Out (-) Orange - Left Front Out Black - Common Red 12VDC In
Here is an update that makes it more clear... Sorry for the original confusing post Roadmaster EA400N Wire Colors Brown - Right Signal In Gray - Right Common (-) Pink - Right Rear Out Dk Blue - Right Front Out Green - Left Signal In White - Left Common (-) Yellow Left Rear Out Orange - Left Front Out Black - Ground Red 12VDC In
There are two sides one with v and the other has five but I'm missing one color to hopefully be explained hey side has red yellow pink orange purple B-side has white gray blank green black the blank is my missing color from what I have read I'm assuming it will be Brown any help without a wire would be awesome
SOURCE: how do i wire an equalizer without any wiring diagrams
1. bottom right( red wire 12 v dc on/off ignition switch)
2. top right( blue wire with inline fuse to amplifires)
3. bottom left( black wire ground)
4. top left( blue wire stereo remote wire)
I have a pdf photo diagram I made just e-mail me and ill send it to ya. hope this helps
SOURCE: need wire diagram for clarion 500EQA equalizer
Your installation manual is not anywhere to be found since the product you are inquiring about was made 1985-87... however, by deduction, you can figure it out yourself...
You need a Power 12V Constant.
A 12V Switched
A Ground
And Signal Cables.
Reply with the wire colors available to you, and I will tell you what is what.
Yellow is usually constant 12V.
Red is Ususally switched 12V.
Black Is Ground.
RCAs are self explanitory.
If your EQ has HI Level outputs, the color scheme is a little more complicated.
how do i hook up my equalizer color code info
SOURCE: wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
wiring diagram for royal sound equilizer 100 watts
Old school100 watt 5 band response Roadmaster equalizer wiring diagram
