To dectivate child lock press the key with the clock symbol for 5 seconds. The child lock will deactivate.
If it still does not then you may have shifted the programme dial. Rotate the dial through each programme and try deactivating child lock in each programme setting. The child lock will deactivate only in the original setting that it was activated.
How to open key lock
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently.
kitchen cabinets
Hi, above solution (including the comment around trying to unlock at each setting works perfectly!!!) Siemens had advised that id need to replace a control board which was very costly! you've just saved me a fortune! than you SO much!
