Your lcd screen is going bad. You can verify this by plugging an external monitor to your laptop. if the external monitor shows without the vertical stripe it means the video card is good but your old screen is bad. If the external monitor shows the stripe then it means the video card is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
SOURCE: dell studio 1737 mousepad not working
You can try the steps below and this definately should fix the issue.
Download and install the latest touchpad driver:
Uninstall the touchpad driver:
1. Click the Start button, point to Settings, and then click Control Panel.
2. When the Control Panel window appears, double-click the Add or Remove Programs icon.
3. Locate the software for your keyboard or mouse in the list below.
• Microsoft IntelliPoint software
• Logitech software
• DellTouch software
• Synaptics software
• Alps software
• Set Point software
4. Click to highlight the device name and then click the Remove button.
5. Follow the prompts to uninstall the input device driver/software.
Download and Install the Latest Touchpad Driver Available:
Please follow the link below to install the latest touchpad driver.
http://tinyurl.com/5k9tth
1. Locate “Input device drivers” and click on (+) sign next to it.
2. Select “Touchpad”, click Download Now. You may receive a warning and an option to run or save the file.
3. Click Save.
4. When the Save As window appears, designate a folder (desktop) to save the file that is being downloaded, and then click Save.
5. When the download is complete, go to desktop and locate the same file.
6. Right click on it and run as administrator.
7. Click on allow and follow the simple instructions to update the touchpad driver.
Please do not forget to rate the solution.
Regards,
Musheer.
SOURCE: Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones, then replace the speakers. Must be a lose wire or something of that nature.
SOURCE: instructions on how to replace lcd screen for dell
All the info you need are here.
http://support.dell.com/support/edocs/systems/studio1737/en/SM/display.htm#wp1109848
SOURCE: dell studio 1737 laptoplost BIOS password called
BIOS password is NOT able to be Cleared by taking battery out, is stored in NVR. Is impossible to hack, crack, unless get special DELL code. Must contact DELL. provide proof of ownership, a receipt etc, then they will send you special code to enter. OR look for pay For site on internet.
SOURCE: how can i remove a
Since you drive does not open using the button nor with the mouse (open my computer - right click on the proper dvd rom drive - choose eject), software may be interfering with the normal operation of the drive. Do the following:
1. Attempt to Eject the CD in System Setup. Reboot the computer and tap the F2 key while at the Dell logo screen to enter System Setup. Then attempt to eject the CD tray using the button on the drive. If the drive ejects properly, there is a software conflict that needs to be resolved.
2. In case that the solution before didn't help, locate a small hole near the eject button of the tray. Use a paper clip in order to put it in this hole and push the internal cogwheel to rotate and open the drive.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
