Was doing great then suddenly started. Have taken apart and cleaned all hair and dirt.
It sounds like the 9-beep error. You can fix it by buying a repair kit from www.eesolutions.ca. I fixed mine in about an hour and a half.
If you get 9 beeps, than this is a known fault that can be fixed easily if you want to DIY. iRobot will not fix it ;-(
you can see the step by step manual of fixing this Roomba HERE
have fun fixing your iRobot Roomba
Avi
SOURCE: spins, stops and can't find dock
The problem is your Roomba's bumper. Tap it with your hand about a dozen times, blow it out with compressed air, and then try running the Roomba. If the same thing occurs, call support at 1-877-855-8593. (Be sure to have the Roomba with you when you call.)
SOURCE: backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
SOURCE: Took Roomba apart to clean and now the pick up
You can go to www.iRobot.com . This is the roomba website. You should be able to find replacement parts, customer support, videos or the Roomba product, and more.
When you cleaned your Roomba, did you also clean the wheel wells and outer most edges of the brush brush cartridges? There can be lint, threads, and at my house, cat hair, wrapped around the outermost edges of the brush cartridges.
I hope my suggestions help. If so, please contact Fixya and rate my solution.
Thanks and Good Luck!
