MSI A5000-040US (9S7-168344-040) PC Notebook Logo
ringo Posted on Apr 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an MSI A5000. It does not come with a firewire port but I'm trying to find out if it's possible to purchase one to install. If so, what kind?
joecoolvette
Level 3:
  • MSI Master 5,660 Answers
  • Posted on Apr 19, 2012
joecoolvette
MSI Master
Level 3:
Answers
5660
Questions
0
Helped
2194751
Points
18014
1 Related Answer
Frederic Marcotte Piche
  • 40 Answers
  • Posted on Mar 22, 2011
SOURCE: I NEED THE DRIVER FOR
Hi, here is a link to the official driver page
http://www.msi.com/product/nb/CR500.html#/?div=Driver
My msi a5000 the screen don't work when I started the laptop
msi a5000 -nnnnnno NNNN told, so guess this.
MSI A5000-222USLED back lamps so not dead those.
w7 when new DaY1.
100% DEAD SCREEN???? NO TEXTS NO ICON LOGOS/
c14 carbon 14 dating is first. 2009
omg manuals gone now at MSI,
next time buy ASUS or dell , shame on MSI.
Well does doing the intel reset work;
hold power for 10 full seconds and release
cured?
next drop that nasty old huge battery off the bottom of PC
remove ac power pack. for 15minutes
then put back only AC power pack and hold power button for 10 full seconds and RELEASE IT.
WORKS OK NOW?
lots more but I stop here for evidence from you.
is the bottom tag shows
MSI MS-1683
this is the true model not a5000
but manuals not there MSI. not sure why.
2009 PCs have CCFL back lamps not LED
and go dead at 20,000 hours or even 5 years old.
dead. as a dead mackerel.
this is a CCFL cusp year I do see some are LED
2009. but no full model told by you
vast sub models there are, 222US is USA.
not told you. yours./
Firewire port usff 7010
If you're asking if a Dell OptiPlex 7010 USFF will support Firewire the answer is No...Unless you purchase and install a Firewire card
The OptiPlex 7010 USFF has the following external connections:
  • Front Panel: one microphone connector and one headphone connector
  • Back Panel: one line-out connector and one line-in/microphone connector
  • Network Adapter: one RJ45 connector
  • Serial: one 9-pin connector; 16550 C compatible
  • USB 3.0: Back Panel - 2
  • Video: 15-pin VGA connector
  • 20-pin DisplayPort connectors - 2
I don't recommend any USB to Firewire convertors but if you can find a Firewire Convertor PCI Express Card you can try installing it but remember the USFF has only one Mini PCI Express 52-pin connector, I've highlighted a possible product. It allows for Firewire 800 speeds. The included optional internal Molex power connection is only required if your Firewire device doesn't have its own power adapter
SONY DSR PD 170 OR 170P IS THE CAMERA MODEL AND LAPTOP IS SONY VAIO VPCEG18FG. The camera has a DV firewire port and lap top has only 3 usb ports. I tried connecting it with a cable that ha s firewire...
This Camcorder does not support USB streaming with the Windows 7 Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.The Firewire to USB cable won't work with your camcorder,you will always end up with this error.
Click the link below for the instruction to transfer the video to the Computer using i.LINK cable.
>> http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
You Sony vaio laptop doesn't have firewire ports ,in this case you will need to purchase and install an firewire card ..>>
see link >>
http://www.ramelectronics.net/computer-parts/computer-accessories/firewire-i-link/firewire-cards/29972/prod29972.html
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Please let me know if you need further assistance on this issue .
Its showing just blue background on the screen wita mesage NO SIGNAL.
If you are trying to capture from a digital camcorder (tape), you have to use a firewire connection, USB does not work as stated in requirements.
Adding to what Walt said, firewire cables don't connect to a USB port. If you don't have a firewire cable, you need to purchase one. And if you do, don't buy a cheap one. Buy cheap, buy twice.
May 06, 2011 • Cameras
How can i download the contents of my mini tape onto the pc ?
you don't convert the files, you just downlod them via a firewire comnnection.
If you have a mini dv (cassette) camcorder....
Your dv camcorder needs a firewire connection (ieee 1394) in order to download video, your PC probably did not come with a firewire port, so you will have to buy one and install it, since most computers (except possibly brand new) don't come with a firewire port, your camcorder did not come with a firewire cord so you have to purchase a cord too. Your camcorder did come with a USB cord and that is used for downloading stills from your camcorder. Make sure your camera is in playback mode.
Open your editing program and choose the capture mode.
The fine print in your manual makes reference to firewire (ieee 1394) connection....
thanks.
Apr 11, 2011 • Cameras
3helpful
Panadonoc pv-gs19 camcorder
The USB port on the camera is to download still pics from the Camera's SD Card to your computer. USB connector is not for video downloading.
For video downloading you have to use FireWire port. Your computer must have a FireWire port too. You will need some sort of video downloading software - like Microsoft's MovieMaker. There are some free software to download videos from mini dv camcorders to computer. It takes 1Hr to download 1Hr tape - you have to play it all to record it all.
3yrs ago when I purchased this cam, I did not have FireWire port in my computer. I searched online a lot and found a way to download video using USB - it was tough, complicated. It was possible, but quality was too bad and too many dropped frames.
If you do not have firewire port, google for FireWire PCI Card, should be <$10. You have to install it inside your PC. Also search for FireWire cable ($10+/-) that will match BOTH camera and PC ports.
Thank you.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
