Sony VAIO VPCEE31FX Notebook Logo
Anonymous Posted on Apr 09, 2012
How can restore the laptop without the cds? - Sony VAIO VPCEE31FX Notebook
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
145
Points
Shut your computer down completely. Boot the system up and press the F10 button (located above the number 9 key). Press <Enter> when the first menu appears. You will be taken to the hidden partition which ALL current Sony VAIO Computer have. I am a Sony Engineer that actually worked on this feature...
Dan Shibata
Level 3:
  • Master 542 Answers
  • Posted on Apr 10, 2012
Dan Shibata
Master
Level 3:
Answers
542
Questions
0
Helped
65852
Points
1061
Restore hp pavilion dv7 1464nr to factory settings windows
Step 1:
Which operating system ?
Restore Hp laptop factory settings without a Restore Disc Turn on the HP laptop. When the blue HP screen appears, press the "F10" key repeatedly until the "Recovery Menu" appears. A progress indicator informs you of the time before the recovery process is to take place. Click "Next" in the Recovery Menu. Decide whether you want to perform a nondestructive or destructive recovery. A "nondestructive recovery" does not format the laptop's hard drive or erase any personal files on your laptop. However, a "destructive recovery" formats your laptop's hard drive and erases any personal files you have on your laptop. Click "Yes" to execute a "Normal, nondestructive recovery." The restore process begins and your laptop restarts. Alternatively, to execute a destructive recovery, click "Advanced." Click "Yes" to start the "Destructive recovery." The restore process begins and your laptop restarts.
Restoring with CDs Back up all crucial user files if you are able to do so. If your computer will not burn CDs, use flash drives of 4GB or higher to store your data. Alternatively, you can use your network to transfer files. You can then back up your data to CDs at your leisure. Detach peripheral devices such as removable media drives, USB drives and your printer before recovering. Also remove any additional hard drives by disconnecting the cable from the back of the computer. Leave your monitor, mouse and keyboard attached to the computer. Shut down your computer. Place the first recovery CD in the CD drive. If your recovery files are written on a partition, you may be able to select system recovery from the splash screen and your computer starts. Select the recovery option you would like to use. To perform a destructive recovery, click the "Advanced" menu option. Select "Destructive Recovery" and click "Next." To perform a non-destructive, or system, recovery, click "Next" from the opening screen. Watch the computer while it is recovering to the factory settings. Watch for any errors, as the computer will wait indefinitely for a response from you, slowing down recovery time. Also, you may need to insert additional recovery CDs as the recovery program requests them. b> Restoring With Recovery Manager Click the Windows "Start" menu, type "Recovery" in the Search field and press "Enter." Click "Advanced Options," choose "System Recovery" and select "Next." If you are prompted to use Microsoft's recovery program, select "No." Choose the option to back up your files, if you haven't done it already. Once that is complete, choose "Next" to begin reformatting the drive and returning the system to factory settings.
1helpful
Clean acer 5742 restore to factory setting
Try my hint on how to restore a laptop to factory settings. http://www1.fixya.com/support/r10606238-restore_computer_factory_default
If your laptop doesn't have a restore partition, you should have received CDs with the computer that will restore the system. If you don't have either, try to find a friend who has the CDs. Acer will charge you a fortune for CDs.
Jim
2answers
Restored laptop to previous date due to virus protector jumping on my screen and not letting me operate the laptop. Let laptop sit while it restored, and went straight to black screen. What can I do?
If you have sensitive and important data here, best solution is to get your harddrive to your local IT specialist for backup and then Windows reinstall.
But if you dont have any important data on it just reinstall Windows and it should be OK If reinstall dont solve your problem then it might be a hardware related problem
I have acer 5620 extensa how to install system s/w in xp operating system
Take the original "System Restore" set of CDs that were shipped with your computer, and use them.
If you cannot find them, telephone ACER, and order a replacement set of those "System Restore" CDs. Probably $20 plus $20 for overnight-courier delivery.
Restore toshiba A40 to factory settings
Toshiba Factory Reset
a couple of ways to do that without the CDs - if available on your PC
  1. 1) If you have a recovery partition on the laptop - have a read here to see if you have one http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=recovery+to+factory
  2. 2) This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
If that option is NOT available then you will need to Order CDs from Toshiba - http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/Recovery-media/m-p/9148#U9148
Hi i have a ibook g3 { i just bought it from a friend} i can i restore to a factory settings without a trouble
To restore an iBook G3 to factory settings you need the installation CDs that came with the iBook. Ask your friend to find them. Sometimes you can purchase replacement sets on eBay, but they have to be for your exact model. Please realize that the original installation CDs that came with this iBook will contain OS 9, not OS X, so I question whether you really want to restore this machine "to factory settings." What you may choose to do instead is a "clean install" from a more recent retail OS X CD or DVD.
2answers
Hi, i need to resore my laptop to its original state, but do not have the packardbell support on my laptop. How else can i restore? Thanks Sean
If the system restore point was not created, unfortunately this content is unable to help you any further.
Factory restore with zd8000
If you press F11 and you have the restore partition on the hard drive, you don't need the disks. All the information that was there from the factory will be on the partition.
Help, I need to restore back to original state!!
You might wanna try formatting the entire drive, then reinstall all programs from the cds it came with.
Recovery partition - repair
You have obviously deleted the partition that the laptop could recover from but usually if you are supplied a cd to recover windows, there is normally a drivers folder within the cd but not the aplications, such as anti virus although these are only for a trial period. for things like microsoft works if supplied, are normally on a seperate cd. Without knowledge of your partition software, you should be able to partition the HDD and then copy the files from one drive to another, but the restore may not work as the system files may not weave together when you come to restore. I would imagine it's only the drivers that's youre main concern, which you can install from your other laptop.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
