LG LMV1630ST Microwave Oven Logo
John Christ Posted on Apr 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Some panel buttons are not working on my LG LMV1630ST
sctheesfeld
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 06, 2019
sctheesfeld
Contributor
Level 1:
Answers
Questions
0
Helped
1969
Points
8
This is what I did. Had to do this a few times, but the last time haven't needed to for a while.
Pull the oven out from the wall. Turn off the power or unplug. Behind the control panel on the back, unscrew the upper access panel. You will see large ribbon cables connected to the touch control panel that the touchpad operates. It's pretty obvious what the large touchpad ribbons are. Disconnect those. You will have to unsnap part of the plastic holder that clip the ribbons into place. Those ribbons get full of steam and particles and as a result have a poor connection to the touch panel. Wipe them off with cotton balls or paper towel keeping them free of lint and such.
I originally used rubbing alcohol but you have to be very careful not to rub off the metal connections on the ribbon. If you start to see any removal the metal on the ribbons, stop right away. If you don't want to use alcohol, use water instead but get them clean and then dry.
Reconnect the ribbons making sure they are secure with the clip, and test the panel. What I did this last time is used a little bit of electrical grease and put a thin layer on the ribbons.
That has solved the problem for several months now and I haven't had to repeat this process since that time. I did actually have to trim the ribbon ever-so-slightly with a pair of scissors since the first time I did this a few years ago I was too aggressive in rubbing the electrical contacts clean. I ended up actually removing some of the electrical contact material at the end of the ribbon the first time when I was too aggressive.
Anonymous
Level 3:
  • LG Master 6,771 Answers
  • Posted on Apr 06, 2012
Anonymous
LG Master
Level 3:
Answers
6771
Questions
0
Helped
1779466
Points
21413
The problem is in the keypad control board and must be replaced, I would consider cost before you allow the go ahead.
1 Related Answer
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 25, 2009
SOURCE: How do I replace a LG LMV1630ST microwave oven door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
2answers
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Nothing on keypad for my microwave works
Be very careful around microwaves they have very high voltage inside them that can be deadly. As for the control panel its very common for grease and oil to get behind the plastic film of the control panel, once it does the buttons will stop working since the grease insulates the contacts. Unplug it from the power, let it sit for 60 minutes to make sure all power from the high voltage caps has dissipated. Get access to the back of the control panel. You will probably have to peel back the control plastic on the front to get behind it. One behind clean all the buttons and contact areas. Reassemble, and it should work.
LG LMV1630ST over the counter microwave has fan that will not shut off
Unfortunately, about the only thing you can do is to replace the switch. We don't service microwaves that often so I am not to sure of where the switch is located on your unit. So here is the layout for your unit, and you can find the correct switch on the diagram and then look it up on the right side.
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Microwave-Parts/Model-LMV1630ST/3204/0123370/Z1006010/00004
The numbers 1 3 5 9 0 and the kitchen timer button on my control pad do not work. Do you think it would be the circuit board for the control panel ? If so do you think it will be easy to fix once I find...
It will be fairly straight forward to fit and one should be able to purchase a spare control pannel from ebay, espares or from the manufacturers agent.
Hope this helps.
6helpful
Turntable won't turn
Look at the front panel, at the bottom, in the middle.
Identify the button labeled "Turntable On/Off".
Push it.
Slap yourself on the forehead.
Next time you fumble to turn of the light in the dark, push the right button.
5helpful
My LG LMV1630ST has an issue with the clock. The
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Is it a US model (made for 60HZ power) being used overseas
(50HZ power)?
* * * * * NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more FREE help & do-it-yourself advice.
William E. Miller
[email protected]
http://www.microwavedisplay.com
LMV1630st sparked and then stopped working.
http://www.fixya.com/support/t886241-power_turns_off
please use this link to view another servicemans explanaton of what your problem is and hopw to address. In essence, you should ALWAYs press the stop button before opening the door... Hope this helps you...
Lg LMV1630st stainless steel microwave oven
Make sure the door is aligned and closes safety switches.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
