I am not a vertinarian. However, I do know there is more than one ailment which can affect a cat's eyes. Most of them can be serious. Make an appointment with your veterinarian to have your cat's eyes examined SOON!
It is never a good idea to leave on eye makeup overnight.Leaving makeup on your skin overnight can get into your eyes and can possibly be a cause of eye infection. When removing eye makeup, it is important to keep in mind that the skin around your eyes is really sensitive. Being harsh on it can produce wrinkles and fine lines. Thus, you should always be gentle when taking off your eye makeup. Gentle eye makeup removers made of readily available oils found at home are the easiest and best way to remove eye makeup while providing moisture for your skin. You can make gentle eye makeup removers through the use of natural oils. Some oils that you may consider are olive oil, castor oil, jojoba oil and vitamin E.
Olive Oil- promotes a smooth radiant complexion and helps maintain the skin's elasticity. It can also be used all over your face by mixing it with honey and egg yolk.
Castor Oil- a natural remedy for dry skin. It is also an affordable beauty aid that help thicken and shine your brows and lashes, and helps you grow your lashes longer.
Jojoba Oil- wonderful for those who suffer from sensitive skin conditions.
Vitamin E- acts as a powerful antioxidant.
You may use one of these products alone or a mixture depending on the ratio and consistency that works best for your skin. It is also important to keep in mind that all of these products are natural and are subject for spoilage. You may have to keep your homemade remover inside the fridge to prevent it from going bad.
Women scour a beauty forum and online reviews to find the best makeup products; however, finding the right product is only half the battle. You'll also need the right tools and application methods to achieve the most flawless look. Read on to learn beauty advice for applying makeup. <br /><br />Creating a full lip. Apply primer to the lips, which allows the pigment to stick better and last longer. Then, apply a lipstick that is moisturizing to create a plumping effect. Finish off by applying a clear gloss over the lipstick to achieve fuller-looking lips. <br /><br />Highlighting your eyes. Play up your eyes by choosing colors that complement your eye color. If you have green eyes, choose lavender and purple eye shadows. Highlight blue eyes with shimmery browns and deep blue. Those with brown eyes should choose emerald greens. Use the lightest eye shadow color on the lids and the darker color for the eyelid crease. <br /><br />Achieving flawless skin. First, apply a moisturizer with SPF to the skin to smooth out any dry areas. Then, use a foundation brush to apply a primer all over your face. Finish off with a light coverage foundation and dust with powder to set the look.<br /><br />
oakley always greases their hinges. it's possible they missed one. you could even try to loosen the screw the smallest bit or, take it to a eye glass repair place and they could take it apart all together and and a small amount of grease for you. i doubt they would even charge you for something so simple to them. couldn't hurt to try. if you don't notice anything cracked or abnormal otherwise, i'd say thats all you need to fully enjoy the sweet shades :D
hope this helps
Hi I also have blonde hair and fair skin. I recommend using Nars blush in a pinkish color and different brown hues on your eyes (but not heavy). Keep it light!
