SOURCE: Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
SOURCE: At start up a sign reads, Projection lamp nearing end of life
Might also want to try amazon.com. Sony is 199
Amazon was around 150.
And you can easily do this yourself.
Theres a little door at the right side if your looking at the front. (left if your looking at the rear) Open that up and youll see another door that has a little latch on it. turn it about a 1/4 turn to the left and it will release that door and pull it straight out. then there is the bulb, and that has a little wire ring that is the release. Pull that up and out.
SOURCE: sony projection lamp is nearing end of life
Here is a link to a website that sells the replacement lamp for $99 dollars. http://electrified.com/Catalog/Items/?CampaignID=Dealtime&ItemID=36414
There might be a local store in your area that carries replacement lamps but probably will not have yours in stock and would have to order it. After you replace the lamp you will need to reset the lamp timer for your TV using the lamp replacement option on the TV general settings menu.
SOURCE: Just replaced the projection lamp but the tv still
Use the "Lamp Replacement" option in the Setup menu to reset the timer.
SOURCE: Lamp or power?
Thats a lamp switch error. You need to keep trying to reseat the lamp till it goes away.
