It's very slow and stops responding quite often. I have XP Home Edition
SOURCE: dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
SOURCE: dell inspiron 6400 system responding very slow on ac adaptor
can i run my dell inspiron 6400 only on AC adaptor?
SOURCE: How do I restore my dell inspiron 2650 to factory
If your system is PC Restore Equipped, it will show show a black page with a blue bar across the top after the Dell Splash Screen. the bar will have www.dell.com in White letters. If you see this page for about a second during the boot process, the system is PC Restore Equipped. At the page with the blue bar, press CTRL+F11 and that will initiate the restore process. Providing the image is not damaged, then restore process takes about 20 to 30 minutes and will return the system to out of box configuration. If there are any errors or if the PC Restore page is not available, then you'll have to do a clean install of Windows using the Dell Windows XP CD that came with the system, then load drivers and applications.
SOURCE: where is switch for wireless on inspiron 2650
hello,
the Dell Inspiron 2650 PC Notebook does not have a wireless lan services.
it only operates with a cabled network service.
take care
SOURCE: Does the Dell Inspiron 2650 Model PP04L have Wifi
Hi jenralley, !Important: "Take a 'moment to rate the help', so I can get 'credit' for the work. Thank you!" - paul7of9
"The "Specifications" do not show {Wifi Capability}.
There is a "built-in Mode," with built-in Network Interface."
"This is use for "Broadband Services." Telephone and DSL {Cable} Internet!"
Specifications
Base configuration
Good
CPU
1.6-GHz Pentium 4-M
Screen size
14.1 inches
System memory
256MB of DDR266 SDRAM
Hard drive
30GB
Graphics
16MB NVidia GeForce2 Go
Pointing device
Touchpad
Expandability
No multipurpose bays, one PC Card slot
Extra features
Good
Bundled removable-media drives
8X DVD-ROM and 8X/8X/24X CD-RW combination drive
Communications
Built-in V.92 modem, built-in network interface
Extra ports
None
Business suite
Microsoft Works 2002
Other features
None of note
Overall design
Average
Battery life (hours:minutes)
Average: 2:18
Weight (typical/minimum, in pounds)
Heavy: 8.3/7.2
