Your ASUS cannot find the hard drive to boot up.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
SOURCE: computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
SOURCE: How can i reboot my laptop?
It is either not seeing the HDD and/or the boot sector on the hdd has been damaged. Any repair you do will only be possible after you boot to an environment. If you can get a bootable CD made, that would be one option. Bootable USB is another. Once booted, you will then be able to examine the HDD to see what the problem is.
Does the bios show a HDD at all?
SOURCE: reboot and select proper boot device or insert
check 1st is there any memory card plugin or not if plug then remove and restart the system 2nd install operating system .. if same then repalce hdd.. thanks...
SOURCE: when I turn on it says Reboot and select proper
This problems would most likely be caused because of your boot order has
been changed in the BIOS settings. If you have a floppy drive as your
first boot device and your CD ROM as your first boot device, your
computer will try and find media on these devices to boot from, if you
don't have anything in the drive this will happen as it did"Reboot and
select proper boot device or insert boot media in selected boot device
and press a key" this just means that your hard drive that has your
operation system installed is not your primary boot device, however it
should be. To change this you need to enter BIOS set up and find where
these settings are and change your boot order so that your hard drive
with your operating system is installed on is the first boot drive, as
for your second boot drive, its really your choice.
Boot and hold F2 to get to BIOS,next Go to Exit tab and choose Load Setup Defaults.Exit and Save.
SOURCE: Machine will not boot.. Black
In this case you need to repair your OS. You need to insert the OS which is a bootable disk, in case of net book you need to connect a USB with OS loaded in it and select boot from USB in bios, for entering in bios you need to press the F 2 button while restarting the computer.
