Nikon Speedlight SB-600 TTL Flash Logo
George Guitierrez Posted on Feb 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When placing batteries, two read lights turn on in the front and the flash does nothing else. ???
Ozzie Morrow Jr.
Level 2:
Champion:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Nikon Expert 305 Answers
  • Posted on Aug 21, 2014
Ozzie Morrow Jr.
Nikon Expert
Level 2:
Champion:
Cheetah:
Answers
305
Questions
Helped
65888
Points
398
Your flash is set for off the camera shooting reset it
Model zx97/5si fridge freezer. Why are the interior light and compressor not working?
My question is whether these three LEDs steady light or flashing during normal mode?
25836454-ucy4wx0s13wzivwce2sy2wdr-4-0.jpg If all three LEDs flash, that means NTC sensors failure!
NTC evaporator sensor is placed on back side of battery evaporator and NTC ambient sensor is placed on front side of batery evaporator.
Battery evaporator is placed in freezer compartment.
Dado
Front turn signals work but flash fast, nothing works in back lights at all
pull the positive wire of your battery wait bout ten to fifteen secs put it back on this will reset your computer
HP 6735s will not boot.
Remove the battery, place the laptop in a warm, dry and sunny spot for several days so it dries out completely. Replace the battery and see if the laptop boots up.
If not then the laptop maybe beyond repair, especially when water was spilt on the laptop when it was running. This could have caused some electronic components to short out.
1helpful
2001 aurora won't start at all. Hook batery up horn horn sounds and doesn't stop head lights stay on but nothing happens when the key is inthe ingition. No clicking or anything at all. alarm on...
The security system does not disable the starter, it only disables fuel to the engine. In the fuse block under the hood, locate the STARTER relay. Place your hand on this relay and see if it clicks while someone else turns the key to start...if the relay is ok then the starter itself is faulty. Good luck, i hope this helps.
2helpful
2answers
My mercedes benz C180 w203,cannot crank in the morning.The battery is perfect.And if it cranks,it does not have any starting problem through out the day.what is the problem ?
Hello! I suspect there is a resistive connection on the + battery cable and/or the - battery cable connections to the starter motor which are temperature sensitive...Using a digital volt meter (cost $25-30 if you do not have one)...Put the DC voltage scale on it's lowest setting...Place + probe on the center of the battery post...Place the - probe on the starter motor + connection...Must read no more than .03 volts...Perform the same test on the - battery post...With the - meter probe on the starter case...Must read less than .06 volts...If readings are incorrect the problem is as stated...And cables need to be replaced...
Guru..................Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
1helpful
The red light on the motherboard is flashing
Remove any drives and then power on, if nothing displays, replug your memory card,processor and dedicated video card if there is any. Lastly reset your bios, just remove the button shape battery and then place it back.
Thanks for using Fixya.
My Quantaray QTB 7500A will not turn on. Placed
Make sure your batteries are inserted properly (+/-) Slide the battery cap on and off several times to make sure you have good contact.
Blackberry pearl wont stay on and red LED light keeps flashing
my phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
Vivitar 283 flash
Please check the trigger voltage.
What, how do I do that, you said!!!!!!!!!?
Here they are:
1. Four fully charged or new batteries into 283.
2. You needs a DVM (Digital Volt Multimeter).
3. Set DVM: DC scale, higher than 10 scale.
4. Black Lead to black DVM and Red Lead to red DVM.
5. Turn ON the Vivitar 283 and wait until light turns Green.
6. Place Black Lead to Outside Silver Contact of the flash.
7. Place Red Lead to Center Silver Contact of the flash.
8. What is the voltage reading? Read the max. V.
9. Anything under 8VDC will be fine.
10. Some versions will be high.
Hope they are helpful to all photographers.
Truly,
Alexander
[email protected]
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
