My password wouldn't work for my Facebook account. I tried to reset the password but the e-mail account was closed. So Facebook had me pick three friends for them to send reset codes to but one of them deleted the e-mail before giving me the code. Facebook will not let me only use 2 of them. They also will not send more reset codes. The screen says ( An account recovery process has already been initiated for this account. Please check the email you provided for further instructions.) This is very frustrating. I have important things on my Facebook account. Please help.
I also same problem i try change password thru phone,. when i log out my fb to phone my new password is cannot access then ill try log in to my computer can't access please help me ,.. im also frustrated i have so many important files to my facebook,.
Teri behen ki chooot
What do you do if you no longer have access to the Email or anything! & my Facebook is very important to me. Please help someone can I contact Facebook directly somehow? Anyone have Marks number?
Good morning to you and Facebook.
Try again with Facebook snd ask them to send you a new password since your attempts until now have failed. If they keep being stubborn and refuse to give the passord, then you can open a new account.
But tell therm how important it is thatyou get into your excisting account.
Good luck
Kolbrun
Facebook is very selfish. I managed to close my account, it was not easy. Try this link and see if they do not pay attention to you.
All the best Kolbrunhttps://www.facebook.com/i.need.a.new.pa...
SOURCE: facebook account locked when opened a new account with same email
G to http://www.facebook.com/help.php?topic=login and type in your problem.
Did Facebook send a message to your email when you tried to reset your password?
SOURCE: My email was used to confirm another account,my facebook gone now
Hi. I had a similar problem... it can be fixed! Email facebook and explain what happened. Be patient and persistent.
send email to:
[email protected]
the first email I received back from them (day after I emailed) was generic saying:
"Our records indicate that there is not a disabled account associated with the address you are writing from. If you are referring to another account that has been disabled, please contact us directly from the email address you use to log in to that account..."
Except the email I was using DID belong to my missing account. So I replied with the SAME original message. And detailed what happened to my account.
I received a SECOND response, identical to the first.
I emailed them AGAIN detailing what happened.
FINALLY (about 1 1/2 weeks later) I received this email:
"Hi Chelsey,
Your original account has been reactivated and you should be able to access it now. Sorry for the inconvenience. If you have any further questions, please visit our Help Center at the following address:
Thanks for contacting Facebook,
Lo
User Operations
Facebook"
IT CAN BE RESTORED!!!! :) [email protected]
SOURCE: Link 2 Facebook accounts with 2 different emails
I'm afraid this is not possible, as per facebook this is their response to your question: http://www.facebook.com/help/?page=804#!/help/?faq=13589
Facebook does not allow you to merge accounts. You need to copy your
profile content (e.g. photos, notes, etc.) and add it manually to your
more active account. Unfortunately, there will be some things you cannot
transfer, such as Friends and Wall posts. Once you have moved all
information onto a single account, please deactivate your old account
from the Settings
tab of the Account page. Afterward, you can add email addresses and
networks to your new account from the Account page. Please note that
maintaining multiple accounts is a violation of Facebook's Terms of Use.
sorry if this is not the answer expected!
good luck!
Testimonial: "Fast and helpful. thank you. "
SOURCE: After entering my email and
Try doing the following:
1. Check if you can login to your facebook account on a different computer.
2. Clear cookies and temporary internet files from your browser under "Internet Options".
3. Try to login once again and hopefully it will not redirect you to another website.
Rate if this solution was helpful.
Thanks
Testimonial: "Thank you very much, worked like a charm."
SOURCE: can't access my facebook account
I am going through the same problem. Go to the help button on facebook and click it. Under using facebook, click on login/password. You are going to see to subject areas: troubleshooting, and functionality. Click on the functionality link. Depending on what kind of message you are receiving, click on one of the links that applies to you and fill in the required information that they ask you. The facebook team will try and resolve the issue as soon as they can.
Hope this helps.
