Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Sometimes, my
car bogs down almost to the point of killing the engine when I start in first
gear from a dead stop. It tends to be more severe when I have been running the
car on the highway for awhile and then hit a stop light/ stop sign in town. I
just thought my car was getting old and I had to be easy on engine when
starting from a stop. However, my battery was 5 years old and I just replaced
it last week. All of a sudden my car wasn’t bogging down at all and it had some
power off the line that I hadn’t experienced in awhile, but about two days
later it went back to the problems in first gear. I am maybe thinking the
alternator isn’t giving the battery a full charge since it wasn’t acting up for
a couple days when the battery was new. I don’t know for sure, but if someone
knows of some possible solutions I would appreciate it. Thanks.
If the idling of your engine only dies off at first gear, you may have a clutch problem. check first if you have fluid in your clutch fluid reservoir, or if its cable make sure that the cable is pulling the clutch lever for a reasonably long travel. there may be leaks in your clutch master or slave cylinders. If your engine behaves well during neutral. it has to be a clutch problem
Ignition timing may be too advanced or ******
Check ignition timing first.
Check for rated idle speed
Check engine compression pressure
