I don't have this particular phone, but generally the sim card in under the battery. Before you start, make sure you have all your contacts and stuff stored on the phone, not the sim, or it all goes bye-bye when you change the sim. Snap off the back of the phone. Don't pry the battery out. Usually you have to look for 2 tiny little "latches" that hold it in. Sometimes there is a lever that you push to release the battery. Then you can see the sim card. Sometimes you release a little metal clip that holds it down. On other phones, you just slide the card out from under the metal holder. Pay attention to which way the card is turned, and don't put the new one in upside down. Then reassemble the phone.
SOURCE: i cant remove the back of my new phone to insert
i have nokia phone 2630 but i havelost my security code.is there any one to help me?
SOURCE: cant access any other GSM card in my nokia 6700 classic
in order for you to use it with a different sim card (carrier) you must buy an unlock code, You can usually find one on ebay, just type on the search box: nokia 6700 unlock code
SOURCE: I HAVE A NOKIA 6700 CLASSIC PH, AND I WOULD
Try restriction codes here http://www.mobile-unlocker.com/nokia-6700-classic/rs2wp9/
SOURCE: my nokia 6700 slide is
What can I advise you is to check if the SIM card is properly connected to the card slot and make sure that this is properly attached. You can also try to use an eraser and rub it to the metal plate of your SIM card first to clean the metal plate before placing it to the SIM card slot.
Thanx all I have found out how to remove sim but now it is saying the phone is offline?
