I kept getting a low system voltage message that required me to press F1 to continue bootup. I later got a keyboard failure message that left my keyboard unresponsive. I tried 3 other keyboards and bought a new one but none worked. I tried clearing the cmos by removing & replacing the battery and I can't access the cmos jumper on the motherboard. Any possible fixes or has the PC reached the end of the road?
SOURCE: Multiple failure notices on screen
your system memorey have a leackage problem, replace a new memory as soon as
SOURCE: keyboard failure on rebooting
reseat the keyboard connector to the pc or try another keyboard
SOURCE: Have a Dell XPS 600 problem. I am getting a
If you have another keyboard try swapping it out and see if it reads the new one. Also a stuck key could possibly cause this error. System battery message probably means you need a new battery for the motherboard. If you replace the battery get the new one before removing the old one. If you leave it out too long you can clear the CMOS
Testimonial: "Thanks alot!!! Very helpful. Thumbs up."
SOURCE: Dimension 8300 boots up to
i think storage battery low indicates that the cmos battery is losing its ability to reatin a charge. try replacing it. if that doesn't solve your problem, you have deeper issues. consult a professional if this is the case.
