SOURCE: Storing Speed Dial Phone Nmbers
Quick Dial Numbers: 1. PICK-UP Hanset 2 PRESS STORE IN - DIAL Phone Number - PRESS STORE IN - PRESS A or B or C 3. HANG UP 4. WRITE name or number of party store in corresponding MEMORY location on Directory Card. Frequently Called Numbers: 1. PICK-UP Hanset 2 PRESS STORE IN - DIAL Phone Number - PRESS STORE IN - PRESS 1 to 9 (PRESS Memory Location Number) 3. HANG UP 4. WRITE name or number of party store in corresponding MEMORY location on Directory Card.
SOURCE: saving phone numbers
hello tjfred.
try here see if your phone listed 5.8 GHz VTech® then click
more info link when you see you phone for the manual.
riz.
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
SOURCE: How to enter phone numbers into the memory/speed dial?
The manual from the GE web site is here:
http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
It's a pretty straightforward process, Pick up the handset press STORE a location (0-9) STORE dial the number STORE
With only 10 storable numbers it's pretty thin, but you also have the last 50 CID numbers to dial. If you live in an area with more than one local area code (overlays) and mixed 10 digit dialing, it looks like you may have some programming to do to make it dial CID numbers properly.
Carl
SOURCE: programming a 2 line ge phone
I found that manual at: http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
