SOURCE: http error $code$
The Error code is a network issue more specifically. If thats coming up when your connected to Wifi it means you're not using the wifi connection. You would have to contact T-Mobile and they may need to remove and re-add the feature to the account which could take up to 3 days to take effect. If you have Total Internet, you can simply change the APN on the phone to internet2.voicestream.com and should hopefully correct the error message as well...
Start > Settings > Connections > Connections tap Manage existing connections, then edit the T-Mobile Data connection and find the APN and change it.
To force wifi to work, try this:
Also check out http://forum.xda-developers.com and see the forums for Wizard which is the HTC model for the phone. Follow the forum to flash the ROM on the device to a different ROM version. You should be able to find a more stable ROM version but the information on the forum may be difficult to understand.
