You can Unlock your Blackberry curve with imei unlock code. it is very simple and eaisiat way to unlock your blackberry curve. get your Blackberry curve Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.
Get this Blackberry Curve Imei Unlock Code .i hope this will help you :)
Good Luck.
Get instant unlock code for BlackBerry only $1.50 / 99p / 1.25 euro @ www.bbcodes.co.uk - cheapest and fastest BlackBerry Unlocking Service in the world!
It is very easy to unlock your Blackberry Curve from verizon to use on virgin,Simply buy unlock code at cheapest rate by BLACKBERRY CURVE UNLOCK CODE provider with instructions.
THANKS ! ! !
SOURCE: i bought a blackberry 8330 curve it is locked to verizon.........
The phone should not be locked. Verizon phones will work on Alltels network. Once it is on the Alltel network you just need to update the PRL. Alltel phones use Alltels network and Verizons network so it really should not matter what name is on the phone.
SOURCE: Blackberry Curve - the key that has the letter P
if you are handy, open the phone up. There is a white plastic glued to the board. Use something sharp and GENTLY peel off where the P is. You can also use a regular hair dryer to help losten the glue. When you expose the metal connections under, use an eraser to clean the connectors on both the board and white plastic GENLY. Hopefully it is as simple as that
SOURCE: need to unlock bb curve verizon so i can use it through metro pcs.
To unlock blackberry curve from verizon network you will be need a blackberry unlock code. With that code your phone will accept any sim card network for any provider so you can use your metropcs sim card in your phone.
