You can get Vauxhall radio codes from this link: Car radio codes in Uxbridge London Gumtree
SOURCE: Need code for siemens vdo 330886636 no 24 469 302
I NEED RADIO CODE FOR SIEMENS VDO 330886636. No.13 138 246. GM020521690276.PLEASE HELP ME.THANKS!
SOURCE: code for car radio vauxhall vectra radio cdr 2005
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Unfortunately
the majority of SIEMENS/VDO codes (including your CDR2005) will
NOT be available for free (or
cheap) from anywhere on the Internet as
access is required to the original factory database…which is not commercially
available..
Try your
Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are
normally the cheapest option) who will connect it to a laptop to read/recode
the memory chip (EEPROM)
SOURCE: VAUXHALL RADIO CDR 2005-VDO. DO NOT KNOW THE MAKE
The CDR2005 is made by SIEMENS/VDO and unfortunately the code cannot be calculated using any program (from Ebay and elsewhere) as it has to be looked up on the original Vauxhall database which is only available at a main Vauxhall Dealer
The alternative is to take it into a Radio Decoding Service who will open it up and wire it into a laptop to read the memory chip (EEPROM) using special dump reading sofware.
Sorry
SOURCE: lost radio code on vauxhall vectra VDO CDR500 radio``
hello i have locked radio and need code u can help me ?
VDO 326559176
No. 24469302
Type: CDR 500 (E)
2F4
Found the serial number its GM050021540034
Gm904932981 Need code
If it is a Blaupunkt radio contact this link with all serial numbers for the code:
https://m.vivastreet.co.uk/account_class...
