xheli 9053 Outdoor Volitation Metal Helicopter Logo
Kieran Robinson Posted on Nov 17, 2011
Volitation 9053 flashing green light when charging brand new out the box
Brought this helicopter took it out he box, plugged in the charger, Green light is meant to go off while charging, instead it flashes green, Any ideas ??
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1142
Points
According to the manual the light will flash while charging and go to solid when done.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Mar 31, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4847
Points
I think it is suppose to flash green while charging and go to solid green when done
Anonymous
Level 1:
New Friend:
  • Posted on Nov 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1142
Points
I have the same problem. I watched the video on helix.com and it shows it off while charging, but mine blinks for like 3 hours then turns solid green so I guess it is done. Anyone care to comment???
  • Anonymous Jan 06, 2012
    Mine does the same thing. This appears to be just how it works.
  • Mauricio Reis
    Mauricio Reis Oct 28, 2013
    Mine is with the same problem
Mauricio Reis
Level 1:
New Friend:
  • Posted on Oct 28, 2013
Mauricio Reis
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1142
Points
I didn't wait 3 hours yet.
I'm trying to fly but the helicopter does not take off...It's weak.
Maybe I wait for the light stop flashing do you think it will be strong to fly again...
  • Mauricio Reis
    I didn't wait 3 hours yet for the light stop flashing.
    Maybe if I wait for the light stop flashing do you think it will be strong to fly again...
I have a skyforce gravity r/c helicopeter trying to fix for my son.When it is plugged in the charger, it just blinks green light. Have it over night, and it is still just blinking green. Have lost remote....
It means that the charged battery is full. Some chargers have a steady glow, others have a flashing light to show that the battery is charged. When you run the helicopter, is the battery fully charged, does the helicopter blades spin flat out? If so, the battery is charged and the flashing light indicates the battery is charged. If the battery isn't charged or the blades don't spin enough to lift the helicopter, or fly for some time, then the battery isn't charged and the charger may be faulty. Take it to a hobby shop to see where the problem lies, the charger and its blinking light, or the battery.
Dec 28, 2014 • Toys
2answers
My helicopter 9053 will not connect to my controller
The receiver is not binding to the transmitter. Make sure the batteries are in good shape in transmitter. I'm assuming it's a 2.4GHz radio frequency.
When you are about to fly, turn transmitter on first after 4-5 seconds turn
heli on or plug battery in on heli. In the manual there should be a page describing radio binding. It will describe on what gimbles to move and
in certain sequences to complete the process. When the light on transmitter stops flashing means the binding process is complete.
Hope this helps.
On my rc volitaion remote on the top the gauge what dose it mean when it flashs
It's in a safety start up mode so there is no accidental start up of the helicopter
while holding model in your hands to turn it on or plug battery in. When ready to fly move throttle
gimble to full up then back down to stop. Light should then stop blinking and the
next time you move throttle gimble up the helicopter rotors should begin to turn.
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes.\r\n ...
A 7.4 volt battery is two 3.7 volt Li-Po batteries in series. Battery has
expired, there is no saving it anymore in fact dangerous just having
around. Li-Po batteries are very sensitive to over charging and also
to being under charged, usually the device that's being operated by
this battery has a safety catch called a BLC (battery limit circut).
So battery won't drop below the safe voltage of about 20% of full
charge.
FYI Don't even mess with this battery anymore, replace it. When Li-Po
batteries blow up they have a VERY high temperature flash and can easily set a garage, house,ect on fire in a split second.
Have fun and be safe.
1helpful
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
11helpful
Instruction manual for double horse 9053 helicopter
i need the owners manual for the " volitation 9053 helicopter "
Dec 20, 2010 • Toys
1helpful
My 9053 volitation wont lift ground, i checked top blade it's not loose from metal shaft, it also wants to spin heavy to the right in circles. I just it so I'm learning
Had a similar model lasted 10 mins i broke this little plactic holder that seperates the blades i bent it the slightist bit and boom never flew again
5helpful
5answers
Hi my helicopter is 9053 , my helicopter working but dont rise , meanwhile it s charging is full , please help me for how to rise many thanks
if the blades are turning and it wont rise check the top blade turn with you hand and hold the lower gear if it spins its loose the clue inside dont hold the turn blades.
solution: get a small drill bit not to big and a drill at the middle of the shaft by the black part make a hole down to the metal shaft and a littel bit into the shaft know get a small screw that woul fir the hold you just made and in to the shaft and it will hold and wala its fixed
Top xheli Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a xheli Toy Expert? Answer questions, earn points and help others
