2006 Piaggio X8 125 Logo
Anonymous Posted on May 09, 2017
2006 Piaggio X8 125 My Piaggio x8 125 LC loses power at max throttle! At first it was at max throttle (100 kph) and felt it was runing short of petrol or choked up. Now it only runs at 3/4 throttle (70 to 80 kph) before losing power continuously if throttle is kept open until I shut my throttle right off and will recover when opening my throttle slowly. (work done = Air Filter, Fuel Filters in lines and tank, vacume fuel pump, Vac lines and pipes inspected, Inlet Hose collapse, Carb cleaned blown out and diafram cheqed for leaks.
  • Anonymous Oct 03, 2011
    Thought of some more to add! new Coil, Plug, Float chamber level.
    When I run at 60 kph +/- the engine will not kill by switch or ignition or both!
2 Related Answers
Michael Green
  • 3799 Answers
  • Posted on Feb 19, 2012
SOURCE: Where does my 2 stroke oil Go in my piaggio Zip 50cc 2007
There should be a tank, usually under the seat or behind the rear side panels. Just fill the 2-stroke tank and don't worry about the mixing, the engine does it on it's own.
tjsb1
Jonathan Buck
  • 446 Answers
  • Posted on Oct 30, 2021
SOURCE: 2014 Piaggio Typhoon 125 strong fuel smell
Is the fuel cap on correctly.
2answers
Piaggio x8 runs rough when warm
Maybe the spark plug breaking down under load when warmed up.Try another spark plug, but make sure it is the recommended one
Piaggio X8 No longer starting.
hi david.
If there is a clicking sound when pressing the starter button that is indicative of a bad starter relay, a fairly common problem problem with Aprilia scooters.
sounds like the starter to me, if you pull off your belt case you should be able to turn the engine from there to make sure its not siezed, if its pulling more than 5amps then the starter motor is likely siezed, dont keep trying it as this could result in the wiring overheating, 0.6 ohms is a decent reading for a ground connection, if you connect your volt meter + from the battery + connection to the starter + connection with volts selected try to start it, the reading you will get will be the voltage being lost between the battery and the starter it should be low, eg less than 1 volt dropped, if not look for poor connections.
or try this link.
How to Troubleshoot Your Piaggio
or this one.
piaggio x8 starting problems Google Search
Dec 10, 2017 • Motorcycles
Bike wont start after recharging battery
may need new battery, a certain amperage is needed to make the magnet pickups work. try jumping of a car battery to test
2006 Piaggio X8 125 My Piaggio x8 125 LC loses power at max throttle! At first it was at max throttle (100 kph) and felt it was runing short of petrol or choked up. Now it only runs at 3/4 throttle (70 to...
Hello crosby, it still sounds like a fuel delivery problem or fuel mixture. Also a possibility is a restricted exhaust. Like carbon buildup that is creating too much back pressure. The carb being "blown out" is not going to properly clean it. The best way to clean all the jets and passages is to remove it & have it boiled or ultrasonic cleaned. The not being able to kill problem is a wiring problem. The spark is not being shut off, (voltage) Trouble shoot these areas and let me know what you find. I hope this helps.
2009 Piaggio Fly 150 will not idle
There is a plastic knob on the side of the carby that you can adjust to set the idle speed. Start the engine and turn the knob until the idle speed is felt above your throttle setting. Now set the idle speed with no throttle and you feel it is about right ( 500-600 rpm ).
2006 passat. judders at approx 100 kph and struggles
Get your tracking checked. Also check the road wheel are balanced.
Top Piaggio Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Piaggio Expert? Answer questions, earn points and help others
