Hello
Check your TV for other inputs, ie, AV, antenna etc. If these inputs are working fine, and only HDMI has the trouble, check the HDMI cable. Reset the TV to its original factory settings according to its manual says. Check these and inform me if you fails to get the HDMI input. OK.
i cant find where to reset it back to factory settings, but i did check and all other input work just not the hdmi ports.
I was able to reset the tv to factory setting and still the hdmi ports do not work.
If you can select all other inputs except HDMI with this set, you have to check by replacing the HDMI cable with an other one. If it has some troble, the set won't get suffician signal or no signal at all. When using High Definision Multimedia Interface [HDMI], the cable must be of the highest quality to keep losst to the digital signals which will be very less in amplitude. Thei is the most important thing to be keep in mind when buying a HDMI cable. OK.
If you do not get result with an other HDMI cable too, the input selector IC on the ciruit board inside your tV is faulty. Replacing it is a very skilled job.
Thank you for your help. Just one more question where would i find a part like this and if i couldnt find a family member to do it what would it roughly cost to have a professional do it? My brother is very smart with electronics but just to keep my option open.
Hello= Just ask your brother whether he can follow the input circuit of the tV and make a repair on it. It is really a skilled work, as I mentioned earlier; experience in servicing this kinds of electronic devices is a must to follow. Just replace the HDMI cable and set the resolution of the tV t lower DPI. If these also does not help you, just get it repaired by either your borther or by any well experienced service technican you know, of by the authorised service center for Toshiba at your town. OK
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
Hope this helps, if so do rate the solution.
