Hi.
Here let me give you some hints.Generally we use to enter 123 or 000.But, sometimes this does not work, at list you can try.Good luck Thanks for visiting fixya
try to restore the phone to factory setting go to settings security reset factory setting default Password 12345
if this will not help keep the help of repairing shop for Flashing if still not work then there is some hardware problem and you must replace the handset (if in warranty) or change the bluetooth.
i recently activated and paired my motorola bluetooth headset to my blackberry 9650. I found online a motorola page through a search which had a support section in which was an illustrated guide for pairing headset to handset, which was extremely helpful. However neither phone nor headset had a correct model number listed, so I choose similar a handset and headset to use for the illistrated support. After turning on the bluetooth, making sure it is discoverable (which should be the default setting on your bluetooth since there is no screen or buttons for you to change things besides on/off and volume), and pairing the two, the phone asks for a pass code for the headset. Now as i said in the beginning you have to choose a certain model handset and headset, so in the illustration they give you pass code for the specific headset, however my headset was not listed. I have a motorola bluetooth model number h505 and i choose model number h520. The pass code given for the h520 was 0000, which worked for my h505. I just went back to the site and there is an option for passkeys (passkey, pass code, and pairing code are all the same thing). If you have motorola, the code is either 1234, or 0000 (four zeros). This is the link directly to the motorola support site, I hope this novel I just wrote helps, good luck. https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/21216/p_country_code/US
The passcode for this and it never changes is 0000 you would input this into your handset for pairing, let me know if you still have trouble, Thanks for using fixya.com
Hi Friend, Network providers lock handsets to their networks in order to protect
the investment they made as you have received the handset at a reduced
price. Therefore the only people that are able to unlock the handset
from the network are the network providers.
If you need a
restriction code you will need to contact your network provider, these
are the people who hold this information. They should be able to give
you this information.
